clean out the idle control valve with carb cleaner and put 2 drops of oil in it, ONLY if you dont have your check light on for the same motor - and please make sure that your genius A/C dude has not hot wired the A/C compressor bypasing the ECU. In a Honda the A/C signal goes to the ECU - and the ECU itself outs the compressor clutch signal
