Does any of you ever encountered the problem of turn off thump (a 'pop' sound when the head unit is turned off) from the speakers.
To isolate the problem I have removed the RCAs from the amp and still the problem persists when the HU is turned off. So its probably the amp causing the thump.
Does it require better grounding or any modification to the remote wire?
Any suggestions/solutions would be appreciated.
