the problem is that i hav a woofer installed in my car but when it gives bass the back plastic cover which covers the speaker starts making a rattling noise which is very irritating and reduces a great deal of sq.Can u tell me how to get rid of the problem?
Same problem is with my CorollA 2011, I think we have to replace that plastic cover with carpeted chipboard phatta.
I faced the same issue after installing my woofer. But after investigating a lot I found its not the plastic cover. Its actually the metal sheet which holds the speakers it is very thin n starts vibrating as the sounf increases. So the remedy is to support the metal sheet so the its vibration would be controlled.
^ how u provide support to that metal sheet, please elaborate
Please elaborate
You can also use some sound deadening material to eliminate these rattling sounds. And sound deadening is an important step in sound system setup.
There are many threads on pw which contain solution for this problem. try searching for them.
Y to install woofer in first place?letting ppl listen the dug dug sound?
good branded spkrs can produce a decent bass, no?
No a properly Enclosed sub is much better than speakers in terms of bass
+1!Sound deadening is a most important step in sound system..Do it,You will surely relief from any type of rattling in car...!
Use a metal rod tie it with that sheet with binding wires.
ok thankx ill try
A desi totka... And it works most of the time too.
Can i do foaming instead of that metal rod thing
of course. just use underlay or jumbolon
I also had the same problem with my civic. I simply took a paper, folder 3 or 4 times and tuck at the point where the rear dekh meets rear screen. Never had any pb of rattling since then cheapest solution lol
Madhouse12 can u tell me how to put the foam and where shud i lay it
And where can i get jumbolon from
https://www.pakwheels.com/forums/car-entertainment-electronics-gps-navigation/147607-diy-sound-deadening
Shud i put the foam only on the rear sheet or any other place too?
