Thank you v.much yes there's is box in my store which aftermarket one which I believe will be better than the desi ones' I just want clear like pure water drop sound
Yes, you're right why I was attracted towards D4 is due to lack of knowledge. Following is output detail of Cerwin amp
50 x 2 Watt - 4 Ohm - THD 0.1% - 4 channel(s) ¦ 75 Watt x 2 - 2 Ohm - THD 0.1% - 4 channel(s)
Neither I'm going for mono amp in future I just wanted to make sound perfect crystal clear and a good punch of beats not a rattling or vibration.
and I got your point. As I'm happy v happy with Kenwood amp giving me good and a perfect Sound quality just wanted clear bass beats and I mostly listen Romanian soundtracks which needs a perfect sound sys
Thank you very much Sir. That helped alot clear info regarding s4 and d4. Conclusion whether I buy s4 d4 according to my amp audio installer will only make 1 bridge connection.
BTW as scorpion pointed out underdog power ratings of my amp what will you suggest should I go for Pioneer 309 S4 happily or have to change decision and go for 3013 as I was using previously 3012 and due to it's performance and I remember it's spider foam went out that's why I don't like Kenwood anymore.
