suzuki workshop officials say that dont install security system in liana plz tell me y and if some body already installed it what can he do this is my genuine problem i have istalled steel mate 888G model which is very good but the mechanics of suzukis workshop says that remove the security alarm as soon as possible as liana has 3 acms installed i asked what is acm they said to me they r computers plz solve my prob thnx
i saw somebody else talking about the liana security system here also. well..first of all...what is the existing security system like and what is the system that you have installed. i am guessing the existing system has an engine immobilizer which routed through a chip in your car key. if that is the case, i will not recommend getting an aftermarket system on top of it unless you are buying a very good and quality brand. I dont know how good steelmate is at all.
Give more information..can u.
hmm,,,i have heard the same thingh about xli,,they say ,its fitted with a computer or somethingh,so one should be careful about instaling a security system in it ,,,,,is there someone who knows about it,,,,,the security system for xli ??
i second @szuberi regarding liana's.
@asd123:
Xli does not have any immobilizer, but dealers say, by installing a security sys 'd void the warrantee. some dealers give leverage by saying install it from XXX shop nearby and it wont make warrantee invalid/void. By computer they meant ECU.
Lianas security system explained on one of suzukis site:
Anti-theft technology in Liana:
The Liana sedan's doors are designed to be virtually impossible to open with anything but the owner's key: For example, if excessive torque is applied to the key cylinder of either front door or to that of the tailgate, a freewheeling protection mechanism is triggered. Anti-picking protection is provided by a rigid cover over all components in the joint section of each front-door key cylinder. In addition, a deadlock system keeps the doors securely locked. Even if a thief were able to get inside the Liana sedan, the steering lock, which incorporates a freewheeling mechanism in the steering-shaft key-lock structure, would frustrate an attempt to drive the car without the owner's key.As a final layer of protection, the Liana sedan has an advanced immobilizer system, which prevents the engine from being started without the owner's key.
@asad123Warranty is void in every new car on installing a security system but theft protection comes first
I myself installed steelmate 888A(two way communication type) system in my corolla 06 and is working fine.Same system is installed in my daewoo racer from last 4 years and had no problem.System features include 250m operating range and a signal recieving range of 3300m which depends on obstacles.(My test in Islamabad city is around 1100m including sitting in buildings like saudi pak).The remote range decreases to 2m only in areas where jammers are installed--Pearl Continental hotels.Car Starter(I have installed the starter wire thru a fuse so that on accidently hitting the start button the car wont start).Auto Trunk(Trunk can be opened when sitting in living rooms without giving your keys to driver or non qualified persons).Arm and disarm mode.locating car in parking lot with help of siren+lights.On intrusion or if car is touched(sensitivity of shock sensor adjustable) owner informed by remotes Beeping sound and remotes Vibration.Visual confirmation in remote LCD of Arm and disarm mode.intrusion attempt,trunk opened.lights flashing,car started .in case of owner of car being wanted slight tapping on front wind screen will inform the owner by beeping,vibrating of remote with small telephone insignia in LCD screen. 888 Model of steel mate also available for around rs.4000but has no starting feature and all models are C quality.888A model is still available in little amounts in B quality with shop keepers who have old stock.Price around rs.5000(you need to search for it as people usually install the 888 model or cheap ones).I bought it at raja bazzar from KAMI decorators in Rawalpindi(he brought many units from different shops and one was the original one which i bought).If interested let me know glad to help you out.The price does not include installation charges.888 costs around rs400.888A around rs.500 and if you install an auto trunk then motor cost Rs.100-300 and additional 150-200 charges.If 888A then around 1000-1500 total cost.if same installation done in isb blue area shops costs around rs.2000-2500
NOTE:-never allow electrician to spark wire on the body to test current,tape all wires properly,Use qualified person to install system---a person doing so from few years in your shape and model car.Never drop the remote on the table from distances.Avoid water contact
@ Shaan,
Your reply is almost a year old but it is very informative!!
You have mentioned the C quality and the B quality equipment from Steel Mate!!
Can you kindly elaborate what is meant by C and B quality??
Thanks!
@Power, well explained the security features of Liana, though you forgot to mention one thing i.e. if you press the LOCK button on the key twice, its impossible to open the car with the Key manually. It can only be opened by the UNLOCK button on the key..
Bro Shoaib, Suzuki dealership guys also warned me for the additonal security system and said that its just not required at all..
The best you could do is to add a tracker.. thats it...
I agree
Hi guys anyone know that Steal Mate 898G is this available in Islamabad or anyone using it..
https://www.pakwheels.com/forums/general-auto-talks/40293-price-steel-mate-888g-898g
pakwheelers ???
Anyone ???
