Kenwood DPX MP5070
Flip-down Front Panel (Manual)
FL Dot Matrix Multicolour Wide Display
11-Band 13-Step Spectrum Analyser
Indirect Blue Illumination for Night Cruising (on/ off)
Supplied with Remote Control Unit (10-key)
2-way Telephone Mute
WMA (Windows Media Audio) Decoder
MP3 Decoder with ID-3 Tag Display
CD Text Ready
Maximum Output Power : 50W x 4 (MOSFET Power IC)
2 Preouts (Rear/ Subwoofer Output Switchable)
Subwoofer Level & Low Pass Filter Adjustable
3 Band Graphic Equalizer/ SRS WOW Effect
SRS WOW Effect (SRS/ TruBass/ FOCUS)
Built In Amp Mute Function
Independent AUX Input
Dual Disc Changer Control Capability (with Optional KCA-S210A)
FM/AM 24 Station Presets (18FM, 6AM)
General Features
Rewritable Security Code/ Security Indicator Function
Key Illumination (Red)
Digital Clock (12h)
Japanese Car Mount (Nissan)
Adjustable Auto Dimmer (13 Steps)
Single CD Features
Multi-session Disc Playback
Folder Name Manual Search Functin without Stopping Audio-play
0-bit Mute
CD Text Ready
CD-R/CD-RW Compatible
DNPS (50 Disc Name Presets)
Random/Repeat/Scan Play
Tape Features
Full Logic Mechanism
Dolby-B NR
Auto-reverse
Tape Advance (DPSS)
Blank Skip/ Index Scan
Changer Control Features
DNPS (Disc Name Presets) with Compatible CD Changers
DNPP (Disc Name Preset Play) by Remote
CD Text Ready with Compatible CD Changers
Direct Access with Remote
Random/Repeat/Scan Play (Disc/Track)
Tuner Features
AME (Automatic Memory Entry)
Up/Down Seek Tuning
SNPS (Station Name Presets)
Selectable Channel Spacing
Equaliser Features
6 Preset Sound Field Control (SFC)
(By-pass/Stadium/Concert Hall/Club Disco/Church/Listening Room)
7-Band Graphic Equalizer (60/160/400/1k/2k/6k/16k Hz)
13-step Gain Adjust (+/- 12 dB)
5 Preset Curves (Flat/Pops/Rock/Dance/Vocal)
17-Band 24-Step Spectrum Analyser
Audio Features
2 Preouts (Rear/ Non-fader Output Switchable)
Non-fader (Subwoofer) Level Adjustable
Built in Amp mute Function
System E's+ (Built-in HPF & LPF)
Additional AUX Input with Optional Unit (CA-C1AX or KCA-S210A)
Attenuator(-20dB) with Smooth Volume Return
