Today i encountered a problem. Whenever i accelerate my car a sound from speakers come that increases with the increase in RPM?What the Problem and plz tel me solution too
Correct me if i posted in wrong section. :S
Agar amplifier hai to us ki ground wire check karain warna speaker ya amp koi earth ho raha hai
or use better insulated wire
Suggestion noted.
https://www.pakwheels.com/forums/car-entertainment-electronics-gps-navigation/95692-any-car-audio-problem-i-can-help-part2-37#post4012878
check the link
Ur amp gain and other nobs might have carbon, try the spray they have in audio shops!
Separate the power wires from the RCA wires. The should be away from each other throughout.
Which car??
Sent from my iPhone 4S using PW Forums mobile app
Cultus efiOn stock speakers and stock cd player
Check the Ground Wire of Pre..
OkBy the way aaj pura din car chalai lekin aaj awaaz nhi aai. But kal raat ko aa rhi thi
MAy be Some Wire Touch with Head LIGHT button..
do u have HID installed in the car?
ive tryed every thing listed above,im still facing this problemive got hids too ,but the sound dsnt go away even after taking off the hids.
try anging your plugs and/or wires.
Too low resistance of plug wires causing emi/rmi noise.The resistance of the plug wires should be 3k ohms per feet..
haunted car perhaps, you need an exorcist
Might be your pre peco fuse blown .... Get it checked!
had the same problem! gave a ground to the pre with a bolt close to it and it never happened again! try that
