My meter shows speed 20 km/h less....How can i fix it?I know many will say go to a mechanic and get it fixed....But i cant..No good reason for that.
Plz Tell if u know.
Open your tachometer yourself and fix it.
Thanx it Helped me alot
Can u tell me how?
Depends on the make/model of your vehicle. Although I suggest you dont play with your speedometer.
Okay i think i shud agree with ur seggestion
Now what kind of mechanic Fixes it?
u probably need calibration. speedometer cable is connected to gear box and there u can find 2 spools(worm gears). but i guess it's not an easy thing to do for u, and u might end up by bringing some oil leaks if u don't connect the cable right.
Quote=UntitledWater
"Now what kind of mechanic Fixes it?"
The cheapest one
I changed my mind now i am going to go to a mechanic..........What kind of mechanic shud i go to?
Yaara any mechanic can basically do this just find someone who is charging your reasonably.
HaHa but i was a BIT serious
Thanks anyway got ur reply
Yaar just take meters cable out and clean it with WD40 may be it is not clean so thats why it is not responding to the actual speed and fix it properly back. But becarefull you should not mess around if it is a tecno meters like Honda Civic and Corollas.
hello!!looks like ur car speedometer back coil was missettled...so u have to open the front panel...remove speedometer and the speedometer wire coming from transmission...the u have to adjust the coil by rotating the reading niddle clockwise and see it....otherwise take it to ur mechanic or electrician of car..worn out gearsare for odometer and trip meter not for speedometerThanxxx
