@zains1000. yea it could be done. obd1 conversion is a ecu change. the older generation honda ecus can be chiped. which means u can tune lots of perimeters when its done.
u dont have to do it. we did it because we could'nt find 440cc injectors. we found 560cc. now the safc(is a fuel controller basically) cant control the big injectors.
to make it easy to u. safc is a device which is installed between the ecu and the engine. and it controls the fuel. like if u put biger injectors then stock. then ull have to trim the fuel down for the engine when the car is not in boost.
ill explain it more detailed..if u need me to
