i need you guys to give me a few ratings which are on the spec sheets. i tried to find it online but i couldnt.
xmax value
Speaker's Resonant Frequency (fs)
Qes
mounting depth
Dear enerlevel .. al i know is following
Mounting Depth 188.8 mm Frequency Response 18 Hz to 700 Hz
Revc (Ohm) dual 3.3 Levc (mH) 1.39 (2 ohms) Zmax (Ohms) 46.54 (2 ohms) Fs (Hz) 33.3 QMS 13.99 Qes 0.63 QTS 0.60 Vas 11.826 (l) Rms 6.003 (Ns / m) Mms 401.32 5.70 * 10 cms Diam 236 mm Sd 0.0437 BL 15.12 (2 ohms) xmax 12.9 mm Hvc 12.9 mm Hag 24 mm
pata nahi kaun kaun s values hain in mai
hello enerlevel !
ener level i request u to use Bassboxpro6 it will helpfull to u ,in this software u can make all type of enclosure , it have graph of , DP ,while it require complete information of sub , amp , wood , enclosure
@geforceyar 4rm where did u get "bassbox 6 pro"i want it 2
do u want free? 6.0 version not fromcrap site like rapidshare
http://www.adrive.com/public/6f260bac47db22fc2801e29cb66d2c1f0ae4012f7065c9fa0691d458914f6994.html download from here and enjoy
why do you want these?
cause , this metadata requires alot in audionic field khair Everlevel will u maddriver from these information is ur amplifer in warrenty?? maddriver , get it be service from that shopkeeper
