Results 1 to 14 of 14
Thread: CUORE 5yh gear problem
    rashed's Avatar
    Aug 2009
    42
    Default CUORE 5yh gear problem
    dear all, i am new to this forum and very much impressed with the level of knowledge of some of the foum members.
    i wana discuss my problem. i have cuore 04 model, it pick and speed is good upto 4th gear but when i switch to 5th gear at speed of 85-90 km/hr, the speed does not increase at full throttle. this problem is at cng with ac on. if i switch off the ac, the speed goes upto 110. any suggestion plz?
    Site Banned Follow
    Zeejigs's Avatar
    Aug 2006
    Rawalpindi
    30
    3,121
    this much speed is enough on cng +ac!!plz forgive ur little cars engine!
    ibadaslam872's Avatar
    Feb 2009
    18
    6,104
    5
    49 Post(s)
    agreed with Zeejigs
    Under the Coconut tree
    rashed's Avatar
    Aug 2009
    42
    Quote Originally Posted by Zeejigs
    ACTUALLY i wana ask why it is not speeding up at 5th gear.
    ha125's Avatar
    Oct 2008
    21
    3,132
    83 Post(s)
    10 Thread(s)
    This is because of the bad tuning of your engine. Its same of our Coure its 2008 Model. Ham ney Toyota Sahara Motors se li thi aur wahan se hi tuning kerwayi thi woh 2-3 din ke liye behtar ker datey they baad mein same problem hoti thi. Apki Coure manual Hai liken Hamari Cx ECO Matic hai.
    Site Banned Follow
    Zeejigs's Avatar
    Aug 2006
    Rawalpindi
    30
    3,121
    5th gear is actually to maintain ur speed on motorway etc,driving on 5th gear also gives gud mileage!
    stonedsaint's Avatar
    Feb 2006
    2,450
    8 Post(s)
    2 Thread(s)
    Cng setup needs tunning .... top speed screw needs to open a lil more .... ur must be giving gud milleage in city run as compared to other cuores ....
    i belive its working fine with petrol on same scanario ....
    zaain_abbas's Avatar
    Aug 2009
    Rawalpindi
    30
    96
    @Zeejigs.... Cure's engine is not that weak my dear.. I can easily does around 130 - 140 on gas and can easily maintain its speed around 160 on petrol... It has one of the best small car engines...
    @Rasheed: About your problem......
    First of all make sure that Ur car pickup is at its max in the lower gears as well cuz if not then u need a proper tuning..
    The reason ur engine is not giving its max response might be bad tuning...
    Get ur engine tuned
    Oil Changed
    Clean air filter
    And get ur CNG serviced by a good mechanic... There are a lot of chances that your car's gas mixture setting is upset...
    IF all that does not work... then Check ur wheel aligments... this greatly affects the top speed..
    If the tires are not properly aligned they may decrease a cars top speed from 150 to 110 easily... plus try to turn ur tyre while the car is on jack to see if they move easily... sometimes the internal Bearing gets stuck and the car becomes really hard to move.. .as a result the engine needs alot more power to move the car... check these small things and I am sure it'll be one of these faults.. If nothing works... tell me the condition of your car in detail .. .and I might be able to spot the problem....
    Performance is all that matterz
    ha125's Avatar
    Oct 2008
    21
    3,132
    83 Post(s)
    10 Thread(s)
    Phir mayoos ho ker hum guzara ker rahey they ke traffic signal per hamey Aik Suzuki Bolan milla jisper Sticker laga tha Abid Computerized Car Tuning Centre. Main ne Dad ko btaya tou unhon ne kaha ke Number Note ker lo. I noted the number, asked them where there shop is? It had 2 branches Gulberg and Model Town. Hamney Model Town wali se Gaddi tuning nahin Adjust kerwai thi ab Alhamd u Lilla Gadi Is as fit as it was brand new
    rashed's Avatar
    Aug 2009
    42
    Quote Originally Posted by stonedsaint
    yeah u r right. thanks a lot bros for this quick response. i will tune my cng kit soon.
    thanks again.
    9BL
    9BL is offline
    9BL's Avatar
    May 2005
    36
    1,632
    6 Post(s)
    its not speeding up because the engine doesent have any more balls left in it ...... for car to gain speed on 5th Gear you are suppose to have a good fuel and atleast 70BHP
    Audi is like a disease once it gets in your blood there is no going back
  12. #12
    ha125's Avatar
    Oct 2008
    21
    3,132
    83 Post(s)
    10 Thread(s)
    Get your car tuned from Abid computerised car tuning centre. Phone number is 0300-8109402
  13. #13
    rockk's Avatar
    Apr 2005
    Sialkot
    3,443
    35 Post(s)
    2 Thread(s)
    the same problem was with my cuore07 last month n i got it tuned n the probelm was cng setting...get ur cng seting frm som expert
    Loaded with SQ setup
  14. #14
    faisalan's Avatar
    Mar 2007
    6
    There is somthing wrong with the your Cuore. I have an 07 model CX ECO and while driving it to my office I do 120 KPH everyday. Its all about maintianing your car right. Treating it with the combination of right motor oil, air / oil filters and tuning.
    Tyres also play an important part. I use Dunlop 155/70/R12. Also try driving your car on pertol once a week, it will make sure that there are no carbon deposits buildup in the engine.
    In my experience, the right tune up is done by the Toyota Authroized Dealer. It takes only Rs.850 but my experience tells me that its WORTH it!
    The power of we is far more than the power of me
