Results 1 to 4 of 4
Thread: Spark Adjustment for Cuore CNG
    atif_osmani's Avatar
    Jun 2005
    48
    18
    Default Spark Adjustment for Cuore CNG
    What is the SPARK ADJUSTMENT feature which Indus Motor's installs in the factory fitted CNG kits of Cuore.
    How is it different from the ordinary Landirenzo kit.
    Any difference if cuore is converted to CNG aftermarket?
    hash4u's Avatar
    May 2005
    38
    24,381
    18
    406 Post(s)
    13 Thread(s)
    13
    spark advancer and timing advancer are the same as far as i comprehend.
    If u can just add a TAP/timing advancer in the after market cuore, it would be good/compatible with the factory fitted one. How ever if u rarely drive on petrol, u dont need a TAP i suggest
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Indus actualy installs retarder which works on petrol to retard timing coz petrol is less frequently used. do check it out from Toyota Dealer. easy installation but not easy money
    Keep a cool head and wear seatbelts!
    robin's Avatar
    Jun 2005
    2,825
    for coure, i suppose, BTDC is 8~10 degrees on petrol and add 8 degees more to run on CNG. well, experience suggests 2 degrees tolerance falls in acceptable range. good tuners also advance spark timing for good initial acc. and help cold starting. let's say upto 2 degrees. but don't fiddle with spark timing unnecessarily.
