Results 1 to 6 of 6
Thread: cuore
    sana_mirza02's Avatar
    Dec 2009
    26
    47
    Default cuore
    my car gear oil leak daily from gear seal.some persons say seal will be change after open the gear box.i do not want to open gear box because my car is new .kindly help me to solve my serious problem
    Dec 2009
    26
    47
    thanks
    MominHaq's Avatar
    Mar 2006
    Select City
    10,842
    16 Post(s)
    Moved to CNG/Mechanical/Technical/Performance.
    Trolls EDPP
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    thats crap - the seals are changed by pulling the driveshafts out, not by splitting the gearbox
    shahidaziz's Avatar
    Oct 2007
    Rawalpindi
    41
    30
    that,s really a very tense condition i also have cuore 2000 same problem leakage of oil.when u park yours car after 5 to 6 h ,standing in front of yours car where the oil present on the floor center or right or left under the car.there are some rubber seals which one are dangerous gear lever seals ,gear box jean,shaft seal if these are faulty then the gear box shell be removed out from engine. but there will be possible the reverse switch or (goda) seals leakage so don,t worry this is simple work in my case my cuore,s (goda) seal and gear box jean was faulty, now this is ok good luck
    cloud100's Avatar
    Dec 2009
    29
    927
    agree with xulfi bhai,but not all seals are done that way like jean wgaira etc,,
    @sana try some other mechanic aswell nd he myt slove it for u,it myt could be a washer leakage aswel.
