Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Vibration in Cuore
    race_addicted's Avatar
    Nov 2008
    Rawalpindi
    36
    1,052
    4 Post(s)
    Default Vibration in Cuore
    Dear All! I'm experiencing vibration problem in Cuore 2007 not only on high speed on highways but also in city driving. I just can't put my Cell phone or other solid thing on dashboard. I got my Tyres changed 1 year ago and there was not any problem in the first 6 months. It has developed in the last six months. Despite wheel balancing for two times and getting front CHIMTA repaired, the problem is still there. Can u guys plz advise what could be the reasons??
    irfansiddique's Avatar
    Oct 2008
    33
    1,765
    12 Post(s)
    hmmmmm, the description is not very clear like what sort of vibration are you experiencing Engine or tires ( i am assuming tires).
    90% vibration occurs because of unbalanced weights. i would advice to you try some other shop other then the one you use to visit. if the problem still persist, get your car Axel checked.
    Nov 2008
    Rawalpindi
    36
    1,052
    4 Post(s)
    Well! when i am driving i feel like my tyre air pressure is low but when i check it, it's ok. I think u would understand what sort of vibration i'm talking about.
    rockk's Avatar
    Apr 2005
    Sialkot
    3,443
    35 Post(s)
    2 Thread(s)
    im driving cuore since 2007 n couldnt find any such problem yet..i dont knw y r u facing such problem
    Loaded with SQ setup
    Nov 2008
    Rawalpindi
    36
    1,052
    4 Post(s)
    @rocK! You are lucky u r not facing such problem but unfortunately that's what im facing.
    Come on guys! I need your guidance as to what might be the reason
    Site Banned Follow
    ZarakD's Avatar
    Nov 2009
    498
    Well i have a coure 2004.I bought it brand new in 2004 and i still own it.The 1st thing u need to do is take a drive in some other coure that dosent has an accidental history and then feel the difference.If not satisfied change ur wheels n rims to coure stock rims and stock general tyres.Are you gettin some sort of noise or its just the vibration.Well if it was a junk like mehran,adam or a cheryqq,their drive is full of vibration due to low built quality.But coure dosent has such fault.
    Badpigs's Avatar
    May 2009
    26
    2,435
    55 Post(s)
    5 Thread(s)
    yr after all the suggestions ....i thnk ur problem is your stock rims ....ager gari ka rim teraa howa hai due to sme accident then 100% usi ki vibration hai ....
    LIVE 4 NOTHING .........................BUT DIE 4 SOMETHING
    Nov 2008
    Rawalpindi
    36
    1,052
    4 Post(s)
    Dear I've changed the rims. Now i've got Alloy rims but the problem persists. Also have got wheel Alignment & Balancing but couldn't get rid of it.
    samach's Avatar
    Nov 2009
    Copenhagen
    33
    39
    when the car starts vibrating put it in neutral and then see if the vibration stops....if it stops vibrating then the problem lies in the axel...hope it helps
    Front wheel drive is the work of satan!!!get a rare wheel drive...
    muddman's Avatar
    Jan 2005
    Bahawalpur
    46
    21
    check for corroded axels as well... if U joints are stiff, they can add to vibes.... If you are parked with engine running, you add gas, and don't feel vibration, then only thing that adds to vibration is Axel, U joints, rims, tires wear, balancing, tire pressure..
    Newbie Follow
    tommytooth's Avatar
    Mar 2010
    Default Vibration in Cuore 2008
    Hi guys,
    I have the same vibration issue that is being discussed in this thread. I have got it checked twice from the toyota workshop and they simply say change tires or rims. I have done that but the vibration seems to happen 5 out of 7 days every week. It's been a month and nobody can tell me what's wrong. Also, hte car behaves very differently every other day like the gas is being cut off and holds back (same on petrol). I am posting in this thread since the workshop people are just making me waste money and not finding the cause of the issue.
    Please help. The vibration feels like one of the tyres is out of balance. I have done wheel balancing and stuff already. The car also virbates if i put it in neutral , as asked in the previous post. Please HELP !!!
  12. #12
    RW
    RW is offline
    RW's Avatar
    Jun 2005
    30
    45
    Get your engine foundation checked.
    "Wow, this is pretty cool, kinda useful too"
  13. #13
    nadeem5476's Avatar
    Oct 2005
    34
    1,000
    Quote Originally Posted by samach View Post
    agreed
    something fishy about number of total posts !!!!
  14. #14
    FaatehRehman's Avatar
    Apr 2010
    Rawalpindi
    25
    222
    my cuore is of 2003 model and it starts to vibrate (exactly its steering) at 100 km/h or above
    it doesnt happen on low speed
  15. #15
    nabeelkhan's Avatar
    Oct 2008
    86
    518
    10 Post(s)
    Interestingly, my car vibrates on 80 km/h, neither below that speed (60) nor at higher that speed (100)
  16. #16
    mn_akram's Avatar
    Aug 2006
    Rawalpindi
    218
    5 Post(s)
    Ur wheels need balancing
    Sent from my Nexus 5 using Tapatalk
    Nauman
  17. #17
    aamirq's Avatar
    Oct 2006
    31
    1,726
    26 Post(s)
    get the engine mounts checked!
    "The world ain't all sunshine and rainbows. It's a very ruff, mean place, and no matter how tuff you think you are, it will always bring you to your knees and keep you there permanently if you let it.You or nobody ain't never gonna hit as hard as life, but it ain't about how hard you hit, it's about how hard you can get hit and keep moving forward, how much you can take and keep moving forward. If you know what you're worth, go out and get what you're worth, but you gotta be willing to take the hit."
    - Sylvester Stallone
  18. #18
    nnabeel's Avatar
    Mar 2006
    37
    398
    this is your allignement and tyres issue, I have also the same issue and it vanished when I changed the tyres and done allignment
    Quote Originally Posted by nabeelkhan View Post
  19. #19
    nnabeel's Avatar
    Mar 2006
    37
    398
    one of the engine foundations is broken or its become which is causing the vibration......transferring engine vibration in dashboard and body
    Quote Originally Posted by tommytooth View Post
    Hi guys,
  20. #20
    racer7's Avatar
    Oct 2012
    1,578
    5
    40 Post(s)
    7 Thread(s)
    Default Vibration In Mehran (2007)
    Friends I have gone through the whole thread but this all is not the solution of the problem:
    Actually two weeks back, I got put in the PACKING on the right front shock of my Mehran which was gone lower from the front right side. The car was going very good without any vibration even the tyres are old.
    After getting installation of Packing I started facing the problem of Vibration from the left side front wheel. This vibration is like you feel when a tyre is gone fat from some place. After that I have got the wheel balancing, wheel alignment, camber adjustment but could not get rid out of this problem.
    Now I have contacted to my denter and tommorrow the car will be inspected by him. Let's see what happens. If anybody has experinced this problem in their Mehran ever, please do share how you got out of it?
