Results 1 to 18 of 18
Thread: Cuore problems...
    adeelg84's Avatar
    Mar 2006
    32
    749
    Default Cuore problems...
    my cuore is giving max 70 kg on a/c..its low what should be the pro?secondly my a/c blower throws air on average but i want the blower to throw air with pressure and beacuse of low pressure it does not cool in hot summer..what should i do to change the blower?
    adeel
    fyq
    fyq is offline
    fyq's Avatar
    Jan 2008
    31
    2,320
    13 Post(s)
    dnt change the blower, just clean the inner condenser.
    and for less average, tell me cylinder size and kit name. also how much air is bloked.
    let the music play
    adeelg84's Avatar
    Mar 2006
    32
    749
    which air block ur talking about..in cuore eco i think its a 55 kg cylinder dont know exactly..
    adeel
    adeelg84's Avatar
    Mar 2006
    32
    749
    another thing i wanna talk about is that on a full cng on highway it gave max 90 with 50% a/c and not going above 100km..tell me the saloution please...
    adeel
    cracked's Avatar
    Mar 2009
    Rawalpindi
    28
    2,959
    35 Post(s)
    tht way to low for a 800cc car...
    REAL men drive manual cars!
    fyq
    fyq is offline
    fyq's Avatar
    Jan 2008
    31
    2,320
    13 Post(s)
    my cuore gives 200 kms on long wodou a/c.
    let the music play
    cracked's Avatar
    Mar 2009
    Rawalpindi
    28
    2,959
    35 Post(s)
    @fyq
    thts becuz of sidegaped plugs ..
    i guess
    fyq
    fyq is offline
    fyq's Avatar
    Jan 2008
    31
    2,320
    13 Post(s)
    na man !
    thts because thts MY CAR
    let the music play
    adeelg84's Avatar
    Mar 2006
    32
    749
    can n e body give me the saloution please..
    adeel
    driver_guy's Avatar
    Jan 2007
    37
    219
    low mileage could be due to a lot of things..
    1- get your tappets adjusted by an expert mechanic. (very important for cuore specially on CNG). Do this every 6 months or 10 K kilometers
    2- get distributor serviced
    3- ask mechanic to check gas flow screw on cng kit. may be its opened too much. After that adjust the idle screw.
    4- use/change a good engine oil (I use Havoline Formula) and always change by or before 5k Kilometers. Also change oil filter at every oil change.
    5- clean air filter once a week. perferably use genuine daihatsu filter
    6- Change the ignition "point" after every 10K Kilometers. Use a genuine one from toyota dealership
    7- Check Spark plugs. You can get very good mileage from stock plugs, just get them replaced/cleaned timely.
    After you have done all this I am sure you will get a much better average.
    btw my Cuore gives about 120 KM with A/C in city in about 7.5 Kg of Gas
    and about 160 KM with A/C on Lhr-Isb Motorway
    I still think this is a bit low and I am thinking of getting the tappets adjusted in a few days.
    ( please always mention the amount of gas when you calculate mileage. There is no such thing as a full gas cylinder)
    adeelg84's Avatar
    Mar 2006
    32
    749
    thanks for all ur suggestions i appreciate.but i picked the fault,the car cylinder wall has a minor leakage and it leaks when i full the tank...now i have to change that...
    adeel
  12. #12
    driver_guy's Avatar
    Jan 2007
    37
    219
    that's unusual ! Was the cylinder rusting or something? how old is your cng kit/cylinder?
  13. #13
    accord7362's Avatar
    Jun 2008
    44
    8,289
    6
    196 Post(s)
    34 Thread(s)
    good day to you
    If you please help "" Is this truth or mith that if we install CNG in CX-automatic cuore its dies and there is no pick up?
    I looked a lot for eco-matic but did not found1 and now I come up with a very good condition cx-automatic with CNG 2007 Isb#
    The owner is saying that it has very good pick on CNG but I also need feed back from experts the guys who own ""CX-automatic & ECO-matic""
    http://www.pakwheels.com/forums/members-member-rides/266031-accord7362s-merc-thanks-god-loved-ones-who-remember-me-prayers ,199119-thanks-god-2011-ford-edge-limited-awd-3-5-v6
  14. #14
    afnan_88's Avatar
    Jun 2005
    Dubai
    28
    2,405
    8 Post(s)
    @ accord , i m using cx auto on cng for past 4 years n it working v good . . .just go fot it
    I Love JDM Cars . . .
  15. #15
    driver_guy's Avatar
    Jan 2007
    37
    219
    there is always some reduction in torque when car is run on CNG. Even a manual cuore's pick will die if not properly tuned on CNG. If you keep it in good nick there should not be a major problem.
  16. #16
    accord7362's Avatar
    Jun 2008
    44
    8,289
    6
    196 Post(s)
    34 Thread(s)
    @afnan & @driver many thanks brothers
    I am also going to change the point system with CDI system to utilize the maximum current.
    thanks once again
  17. #17
    adeelg84's Avatar
    Mar 2006
    32
    749
    it possiblly happened when i did my cng kit service,the mechanic i think havent tightened the wall properly...i.e why some space has been left for the gas to smoke out...
    adeel
  18. #18
    tahirjaved's Avatar
    Dec 2006
    39
    I got 226Km with AC and 247Km without AC using CNG with 220Pressure on LHR-ISB GT Road track by keeping speed between 80-95 Km/h. However, mileage reduces in driving in City due to multiple factors.
