Results 1 to 6 of 6
Thread: should i remove thermostate from cuore
    race_addicted's Avatar
    Nov 2008
    Rawalpindi
    36
    1,052
    4 Post(s)
    Default should i remove thermostate from cuore
    Dear friends! I'm experiencing heat up issue in cuore 07. The temp. Guage needle reaches the maximum point within 5 mins even in the early morning and then stays at that point for most of the time. It has effected its Ac performance too. Should i remove the thermostat and get the fan direct? What are its merits and demerits?
    fyq
    fyq is offline
    fyq's Avatar
    Jan 2008
    31
    2,331
    13 Post(s)
    dnt remove thermostat!
    just luk y is it doing so!
    till thn , just giv the direct earth to the wire connected to thermostat, 2ndly at back of dashborad theres a grip of thermostat of a/c, also direct tht with a jumper.
    but ist try to fix the reasoning of getting heatup.
    let the music play
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    you sure its actually overheating? or is the guage faulty
    irfansiddique's Avatar
    Oct 2008
    33
    1,765
    12 Post(s)
    what is your radiator condition and water level in it. is your car burning water ??
    chinyoti's Avatar
    Sep 2005
    27
    11,965
    5
    108 Post(s)
    5 Thread(s)
    Well the a.c doesnt performs because as the car gets heated up a.c is the first thing that trips. So that you noe somethings wrong if ur eyes dont goto the needle.
    So get it checked y it behaving like that, it cant be just playing with u heating up, probably theres something wrong, eithr the auto fan fuse isnt working or maybe sumthing else.
    Get over the fact that Xli lacks power windows, Its an Xli because it lacks thoose features or else it would be a Gli or an Altis if had all the goodies.
    Nov 2008
    Rawalpindi
    36
    1,052
    4 Post(s)
    Friend! Very Sorry i'm not that good in understanding the word JUMPER. please make it clear to me in simple language. Secondly, Will the removal of thermostat have any adverse effect on the performance of the car??
