Results 1 to 7 of 7
Thread: cuore speedometer-incorrect reading-pl help
    mazher's Avatar
    Jul 2005
    43
    454
    5 Post(s)
    Default cuore speedometer-incorrect reading-pl help
    guys i have a 2004 cuore automatic. the speedometer is giving incorrect reading. for e.g it appears to me giving 10-15km/hr less than actual.
    can anyone advise where to get it repaired in Karachi? is there a good mechanic/electrician for such a problem?
    zia1288's Avatar
    Dec 2004
    28
    6,895
    117 Post(s)
    3 Thread(s)
    Have you changed the tyre size from the original one?
    Almost everyone in Pakistan is doing corruption to the extent they can. Our leaders are doing at the level they can do. So why should we complain?
    zunny's Avatar
    Mar 2008
    Other
    37
    4,107
    5
    29 Post(s)
    2 Thread(s)
    how did u know that ur speedo is showing
    less?if u checked it via a GPS then remember that GPS speeds varies from speedo meter.
    'RESPECT',DIY projects: 1) 'CRUISEMATEC' 1st PKDM 8th Gen Civic with OEM Honda CRUISE CONTROL 2)Steering Audio Controls 3)AUX for OEM 8th Gen 6 CD CHANGER 4)Leather RED H logo!
    mazher's Avatar
    Jul 2005
    43
    454
    5 Post(s)
    @zia1288...no i did not change the tyre size
    @zunny...i checked it with another friend's car moving along at the same speed..also my speedometer needle does not start at zero. instead it drops down even below zero when i stop.
    not sure where to get it checked..
    autophile's Avatar
    Sep 2004
    13,576
    20
    6
    405 Post(s)
    Check the speedo meter cable for any lose joints etc.
    Be polite on the road. Always give way to others, particularly ambulances and pedestrians.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    if its below zero at rest - your problem is right there.. open up the cluster and readjust the needle to zero resting point
    mazher's Avatar
    Jul 2005
    43
    454
    5 Post(s)
    thanks guys..
