Results 1 to 3 of 3
Thread: Cuore: Transmission & Coolant Specs
    Spartacus's Avatar
    Apr 2010
    26
    Default Cuore: Transmission & Coolant Specs
    Can some some please tell me what the drain & refill specifications are for the transmission oil and engine coolant system?
    What weight oil is required for the transmission?
    Thanks in advance.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3989 Post(s)
    94 Thread(s)
    6
    the transmission needs API GL4 SAE 75W90 lubricant while the coolant is Toyota Gulabi coolant
    Spartacus's Avatar
    Apr 2010
    26
    Thanks again. You are a wealth of information. Thanks for helping guys like us whose vehicles did not come with an owner's manual.
