Results 1 to 7 of 7
Thread: Cuore 2004 Automatic - Reverse Gear not Working
    wackywheels's Avatar
    Jun 2006
    39
    7
    Default Cuore 2004 Automatic - Reverse Gear not Working
    We have Cuore 2004 Automatic (Karachi) and its reverse gear is not working?
    New price for automatic gear is 2 lac that was asked from Toyota Karachi.
    Do anybody know good Car Automatic mechanic?
    Is any body hear Pappu Ustaad in Karachi - is he good mechanic?
    Thanks for your advise or reading this thread !
    hash4u's Avatar
    May 2005
    38
    24,378
    18
    406 Post(s)
    13 Thread(s)
    13
    only reverse not working and rest of the fwd 3 gears are fine ?
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3989 Post(s)
    94 Thread(s)
    6
    The reverse clutch piston which in your case is made of plastic is stuck - (usually happens in Cuore) - overheats, warps and gets lodged.
    The guy (pappu) you are talking about knows how to rebuild automatics; but his repairs are only as good as the parts he can find. As there are no new parts found for automatics in Pakistan your result will be highly dependant on the used parts you or he can find.
    I rebuild autos too, and for best results I get full rebuild kits first then open up the transmission.
    p.s. when you meet pappu - tell him that Zulfiqar (VW Golf) said hi
    iLLDuDe786's Avatar
    Feb 2009
    New York City
    11,213
    transmission repair karwa lo and if the problem is more major then import or find a dihatsu mira tranny it will be much cheaper and efficient, dont buy that for 2 lahks they r ripping ppl off
    Jun 2006
    39
    7
    hash4u --> Yes only reverse problem - rest gears are fine
    Xulfiqar --> Thanks for your comments and well noted. 1) is Pappu is trusted & good Mechanic, since his name was reffered by Toyota? 2) are you repairing automatic cars and arrange good kits before opening of transmision ?
    ILLDuDe786 --> where i can find dhaitso mira tranny or any spare parts in karachi, can you recommend good automatic mechanic or should I go with pappu?
    Jun 2006
    39
    7
    I need your expert reply and feedback for pappu ustaad work?
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3989 Post(s)
    94 Thread(s)
    6
    yep I repair automatics - infact me and pappu used to brainstorm together on some complex problems.. anyways - the mira transmission will fit but wont shift properly as the final drive ratio is different and usually Mira come with EFI engines - which also control the transmission shift points - hence it doesnt have a speed governor and sometimes no pressure control cable either - your car has a hydraulic speed governor to shift gears. Mira transmission parts dont fit either - they are smaller inside.
    Your problem is not that bad as Ive seen some seriously bad Cuore Transmissions - they were working without reverse and no O/D and when opened - all the plates were polished clean - (the dirty fluid was its friction material to pull the car) - The reverse no working is very usual in Cuore - Toyota/Aisin used a plastic pressure piston for the reverse pack - (how genius) and it gets stuck when overheated
    There are a few shops that build automatics now - but I cant say anything about them as they never built it infront of me nor did I see the car afterwards
