Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: EPS for cuore
    aali-01's Avatar
    Feb 2010
    33
    560
    Question EPS for cuore
    has anyone experienced EPS in cuore ? i have herd that mira's EPS can fit in cuore without any alteration.
    what would be its cost ?
    wonder_guy's Avatar
    Oct 2005
    33
    3,613
    17 Post(s)
    Yes EPS is possible for Coure....a friend did this nd the total cost was around 3500. All need to be done is u have to get New Kanghi electronic one and ECu and install it.
    Flavor of Life on a 2 Wheeler - Project |Suzuki GS 500e|
    http://www.pakwheels.com/forums/bikes-3-wheelers/220849-project-suzuki-gs-500-a
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    its possible, easy but not so quick, you also need a VSS to make it work effectively, it should go hard when travelling above 55kmh - (motor works against you). A check light made from an LED and a few wires, including, rpm, ignition power, ground
    zank's Avatar
    Feb 2009
    36
    1,484
    21 Post(s)
    Please elaborate...
    smartdevil_striker's Avatar
    Dec 2006
    30
    3,359
    8
    109 Post(s)
    2 Thread(s)
    I don't think that Coure need HPS or EPS.. Its Steering is very smooth so no need of it!!
    Platinum&Iridium Plugs,Performance 8MM Wires,Automotive Bulbs and Bosch Horns for sale Contact: 0333-3035482
    iLLDuDe786's Avatar
    Feb 2009
    New York City
    11,213
    Well you can contact Toyota in getting some info , coz they were offering power steering in cuore back in 08 when eco matic was launched. not sure abt current situation
    margallar's Avatar
    Oct 2009
    9,960
    6
    283 Post(s)
    4 Thread(s)
    it is possible. cost is 10k. only motor will need to be installed regular kungi will work. hydraulic will cost abt 25k
    Zaeem89's Avatar
    Jul 2009
    27
    1,558
    Coure has very light steering i dont think it needs EPS but i do recommend it for alto because it has harder steering.
    Digitalphotofreaks.com
    The Photography Forums
    zank's Avatar
    Feb 2009
    36
    1,484
    21 Post(s)
    Refer my thread you will find all info there, you can also do the same with Coure too.
    https://www.pakwheels.com/forums/gen...tus-eps-vs-hps
    gr8qasim's Avatar
    May 2010
    Sialkot
    25
    448
    I also think that installing eps in cuore is a wate of money as it has already got a very soft steering
    WARNING: I cannot be help responsible for the above, as apparently my cats have learned how to type.
    margallar's Avatar
    Oct 2009
    9,960
    6
    283 Post(s)
    4 Thread(s)
    but at slow speed it takes a lil muscle to turn the wheel.
  12. #12
    margallar's Avatar
    Oct 2009
    9,960
    6
    283 Post(s)
    4 Thread(s)
    if you do get one my advice is that you get a switch to turn it on or off in case it is malfunctioning
  13. #13
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by zank View Post
    Please elaborate...
    The VSS = vehicle speed sensor, our local carburettor engine cuore dont have this as they are still using a speedo cable. The VSS input into the steering control unit will make it know that the car is travelling at certain speed - and would adjust the steering to hard turning to ensure the car does not get out of control. (at speeds above 100 km/h the motor would apply a brake to your effort so you dont spin the car out of line) - older cars with hydraulic assist systems had this function coming from the transmission pressure control valve to (slow down/stiffen) power assist - Anyone who has had a 1986-1990 Accord or even a 1993 to 1996 integra would know - and you can literally see hydraulic lines going into the transmission for this purpose
  14. #14
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by margallar View Post
    As soon as a malfunction is detected the steering control unit stops power assist and turns on the check light.
    even monkeying around with the EPS at idle is a malfunction as the motor heats up along with the control unit..
  15. #15
    aali-01's Avatar
    Feb 2010
    33
    560
    10k !!!!!! that is tooooooo much.
  16. #16
    aali-01's Avatar
    Feb 2010
    33
    560
    yes i have gone through that thread and its very informative but i just need to know a person who has tried this in cuore.
  17. #17
    aali-01's Avatar
    Feb 2010
    33
    560
    Quote Originally Posted by wonder_guy View Post
    3500 seams normal. when did your friend installed this and from where ?
  18. #18
    aali-01's Avatar
    Feb 2010
    33
    560
    any one ?
  19. #19
    aali-01's Avatar
    Feb 2010
    33
    560
    bump
  20. #20
    TRD07's Avatar
    Jul 2009
    27
    235
    i saw a mira half cut.....wid da person offering ABS(complete wid chip) n power steering along wid da engine.
    nt sure abt da price.....but m sure it can b installed without alteration(major)
