Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 51
Thread: yet another problem in cuore
    aali-01's Avatar
    Feb 2010
    33
    560
    Default yet another problem in cuore
    hey guys,
    i am facing another problem in my cuore. the rear springs or shocks are making alot of noise.. like thak thak when ever the car is passed over a cat eye. is it normal for cuore or am i the only suffering one ?
  2. #21
    aali-01's Avatar
    Feb 2010
    33
    560
    i also went to toyota sahara motors today. the mechanic tightened some screw and its better now. but i am not satisfied totally as when it runs over a cat eye. the sound from rear tyre or shock is different from the front one. the guy told me that it due to the weight of the engine in front of the car. i dont think this should be the reason as i never experienced that in my Alto
  3. #22
    aantherax's Avatar
    May 2006
    33
    3,032
    4 Post(s)
    Alto's suspension is softer if compared with coure's suspension ... did you try decreasing the air pressure in your rear tires idea should be 28 PSI ..... do that and check
    ~ Be a responsible citizen and always drive safely ~
  4. #23
    stingray's Avatar
    May 2005
    Peshawar
    37
    859
    5 Post(s)
    consider tire inflation and changing ur tires if required...get comfort tires...they make a lotta difference.
  5. #24
    armaghan_ahsen's Avatar
    Nov 2010
    568
    go get ur ride checked by some experts all will be well
    FLIGHT LT ENGINEER MUHAMMAD AHSAN
  6. #25
    aali-01's Avatar
    Feb 2010
    33
    560
    i have yukohama tires driven about 10k ... i think those tires were the most soft as told by the shopkeeper. also the size is 155/70/12. Now this is interesting. i saw some sticker at the door panel some time earlier and it was written that the pressure in all tires should be 26. so i maintain 26 pressure in all tires after that. but that aint solving the problem either
  7. #26
    driver_guy's Avatar
    Jan 2007
    37
    219
    take it to some old toyota dealership like toyota walton. They are expensive so first ask them for an estimate and problem cause, then share with us what they diagnosed. Discuss it with there workshop foreman not an ordinary mechanic.
  8. #27
    KamranAslam's Avatar
    Apr 2006
    Select City
    14,248
    7
    295 Post(s)
    11 Thread(s)
    9
    IMO: its the shocks problem, the rear shocks do this if they get little bend in some jumps or khaddas.
    I have gone through it in coure two years back.
    I am only responsible for what I say, not for what you understand..
  9. #28
    onlyfaith's Avatar
    Sep 2010
    5,934
    8 Post(s)
    good that at least they are recalling them!
    pretty uncommon culture in Pakistan!
    top documentaries " Tears of Gaza"
  10. #29
    aali-01's Avatar
    Feb 2010
    33
    560
    Quote Originally Posted by KamranAslam View Post
    so whats the solution ?
  11. #30
    aali-01's Avatar
    Feb 2010
    33
    560
    bump
  12. #31
    Apr 2006
    Select City
    14,248
    7
    295 Post(s)
    11 Thread(s)
    9
    I got new shock for the rear do not repair the tak tak one's - for me this worked.
  13. #32
    aali-01's Avatar
    Feb 2010
    33
    560
    As my car is under warranty so i went to the toyota shop and they simply told me that the shocks of cuore never get dammaged
  14. #33
    aali-01's Avatar
    Feb 2010
    33
    560
    bump
  15. #34
    aali-01's Avatar
    Feb 2010
    33
    560
    i will go to bilal gunj this weekend. can any one tell me what options do i have? which car's springs will fit in cuore ?
  16. #35
    aali-01's Avatar
    Feb 2010
    33
    560
    bump
  17. #36
    aali-01's Avatar
    Feb 2010
    33
    560
    bump
  18. #37
    aali-01's Avatar
    Feb 2010
    33
    560
    bump
  19. #38
    ansarali39's Avatar
    Aug 2009
    39
    268
    dear i have the similar problem i only change the rubber
    rubber at joint of shock onserber and body and problem resolved
  20. #39
    aali-01's Avatar
    Feb 2010
    33
    560
    Quote Originally Posted by ansarali39 View Post
    thanks for the reply brother. how much did it cost you ? what car do u have and was it totally solved ?
  21. #40
    aali-01's Avatar
    Feb 2010
    33
    560
    bump
