Results 1 to 3 of 3
Thread: CUORE problem
    shani7494's Avatar
    Sep 2005
    30
    110
    Default CUORE problem
    i have 03 coure AC/ CNG it was working alrite ...from two dayz back when i start it it start vibrating n after 4 or 5 sec ti will become smooth alrite.........n sumtimes in the morning the salf get stuck but when i on n off 2 or three times it will work fine...rest of the day it satrt on a hlf salf...it has new battery n did sereviced salf 4 dayz back....n aonther thing it also giving steam for abt 2 min then it will become smooth...no heat up issue.....kindly tell me wots th problem....i tthink some heat gaskit issue...
    $#@N!
    driver_guy's Avatar
    Jan 2007
    37
    219
    check if she's getting air from anywhere except the intake. Block the intake with your hand and see if engine shuts down.
    geechacha's Avatar
    Jul 2009
    Chakwal
    29
    10
    agree" driver_guy "with definitely the intake problem
