Results 1 to 5 of 5
Thread: Cuore Carburetor Service
    butt74's Avatar
    Jun 2009
    41
    179
    2 Post(s)
    Default Cuore Carburetor Service
    Hi PWs....
    I have Cuore-2003. Now a days I am facing a little problem. While driving when I got to slow the car (due to some "khada" or speed breaker) and press clutch, my car race increases (rpm) no matter it is on CNG or Petrol.
    Moreover on Petrol, while driving when I slow my car, it starting having or giving "jhatkas" unless I press clutch to be in peace
    Questions are:
    1. Whether It is Carburetor Problem?
    2. If yes then how this problem will rectify?
    3. Any workshop recommended for the Job.
    4. Anyother reason?
    be sure to taste your words before you spit them out
    scorpion80's Avatar
    May 2007
    36
    4,320
    11 Post(s)
    get ur car tuned first .. looks like ur tuning is out ...
    as u r facing prob in cng too thats why i guess u should get ur car tuned properly ...
    aqsmohsin's Avatar
    Apr 2008
    33
    49
    first try to check the race cabling if its not stuck ... try to remove the race cable and start your car if it stays good on idle it means the problem is with your cable ... bingo !!!
    if the problem stays check fast idle screw if it adjusted for fast idle. if still stays butterfly of your carburetor can be checked that handles the race wire..
    Well the problem you are telling on petrol could be because of bad timing adjustment.. get it checked from a good mechanic with proper timing gun otherwise no one can do the proper adjustment...One thing should be considered that its because your car might not be tuned on petrol but on CNG....
    butt74's Avatar
    Jun 2009
    41
    179
    2 Post(s)
    @aqsmohsin..... i always used to tune my car from Toyota Township, Lahore. Last time mechanic told me that your carbu. needs to be services thats why i asked whether this prob is due to carb or not. but one thing i tell u that at the end of tuning when they adjust RPM usually they use a machine to adjust but now (in last 2 or 3 tunings) they are not using it tell me ooo yaa there is some prob... ur car is ok as far as rpm concerned dis and dat.. moreover i need to tell you that my car runs mostly on cng (99%).
    Newbie Follow
    khalid4788's Avatar
    Mar 2016
    Default Coure
    Aoa can u help me abt the auto choke is nt working. I m at quetta i change the carbrator but the autochoke is nt working properly help abt that issue
