Results 1 to 5 of 5
Thread: cuore radiator drain plug leaking
    longdrive's Avatar
    Apr 2009
    46
    142
    Default cuore radiator drain plug leaking
    From last few days the radiator drain plug of my cuore (2006) leaks coolant very slowly. I tightened it a bit (although it seemed enough tight already) and it seemed to drip a little more and but after one day I see no more dripping (Strange huh). Apparently the drain plug seems fine (no cracks). I think there is also an O ring inside.
    Do I need to replace the drain plug or O ring?? Any precautions on taking it out for inspection?
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    Just replace the O ring or rubber washer,avoid cross threading while screwing the drain plug and also avoid over tightening.
    Never loose hope in life,every step gives u something.
    smijaz's Avatar
    Feb 2010
    36
    1,100
    60 Post(s)
    3 Thread(s)
    Quote Originally Posted by argtr65 View Post
    ^+1
    In addition to this you can use teflon tape on the plugs threads, it will be a long term remedy to the problem. For application method of teflon tape you can watch the link below
    How to use teflon tape on pipe threads - YouTube
    longdrive's Avatar
    Apr 2009
    46
    142
    - I was quoted Rs. 250 for a new genuine drain plug. Is it fair enough?
    I searched it because I am not sure if ordinary replacement O rings available at spare parts shop would be able to withstand the radiator heat.
    -Secondly, does the drainplug come out by simply inscrewing or does it need pulling out of slot after loosening??
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    replace the O ring with a standard O ring you get from a spare parts shop, it will work, just buy a few in advance as you have to replace it everytime you remove the plug.
