Results 1 to 2 of 2
Thread: Cuore petrol tuning problem
    syedsarosh's Avatar
    Apr 2011
    74
    Default Cuore petrol tuning problem
    i have a cuore 2002, it was running gr8 on CNG, 2.4-2.7 per km.
    I expected it to go good on petrol, but when i switched, it had high rpm at idle. so i removed the air intake restrictor which was attacehd for CNG.
    then it went good for a day, and now agn the idle rpm is high on petrol. it has new oil, oil filter, air filter somewhat 2 month old, two-pin plugs are new.
    is it abt the fuel filter?
    is it about the air intake?
    air intake has two inlet holes, why?
    usually in cuore the air inlet has a narrow duct also, which is absent in my case, so is it the problem? where is that air inlet narro duct goin to?
    cuore doesnt hav choke, so how the tuning is done?
    CNG times are goin out, petrol is basic need.. kindly help early
    aqs29's Avatar
    Mar 2006
    Hyderabad
    3,129
    16 Post(s)
    Better take it to a good CNG mechanic coz tinkering with ur daily ride just ain't right
Tags for this Thread
