Results 1 to 7 of 7
Thread: Cuore Transmission problem
    dragoninja94's Avatar
    Dec 2011
    217
    Unhappy Cuore Transmission problem
    I have a cuore 2006 model , it has been used only 40000km .
    I went for the gear oil checking of my Honda City , so I had it changed .
    The mechanic put the zic gear oil ( I dont know which type but he put zic gear oil in it).around 1.5 litre gear oil was left.
    Then i took my cuore for a check up , to the same mechanic . He told me that the cuore also needs gear oil replacement . Hence he put the remaining gear oil in the cuore.
    Since that day , my cuore transmission is very rough. It uses a lot of force to shift into second gear .
    So could the problem be caused by using a wrong gear oil? As in using the oil of same viscosity in cuore , as the one used in Honda city???
    PKTUN's Avatar
    Oct 2011
    Khuzdar
    1,067
    35 Post(s)
    3 Thread(s)
    bhai gear oil sirf top-up kara jata hai gear oil change kisi problem k baad socha ja sakta hai ap ki car ka owner manual mai iss ka explanation ho ga
    kuch oil ki thickness ka masla hai jo gear shifting mai problem shro ho gai hai
    PKTUN's Avatar
    Oct 2011
    Khuzdar
    1,067
    35 Post(s)
    3 Thread(s)
    Dec 2011
    217
    Thumbs up Hmmmmm
    Quote Originally Posted by PKTUN View Post
    Actually it was not me who took the car to the mechanic ..............
    I always consult the manual.
    I am at a mechanic , who is a real expert.
    He is checking , and will put the oil of normal viscosity.
    imran2d's Avatar
    Dec 2011
    Shaikhupura
    172
    Default Transmission problem
    Quote Originally Posted by muhammadmohsinaslam View Post
    AOA, Friends, I have read all the discussion,as you changed oil and after that you felt problem, the question is that either you feel 2nd gear hard shift in cold condition or hot condition too, and other thing is that always follow the instruction manual, use company recommended oil, mechanic normally think that thick oil can give better lubrication but it is not true,
    cheers!
    Dec 2011
    217
    Smile Fixed
    Quote Originally Posted by imran2d View Post
    cheers!
    Problem was fixed . The race of the car was too much. The mechanic fixed it....the engine noise is very less and smooth gear shift
    zohaib1431's Avatar
    Dec 2015
    24
    Default Please help
    I have a coure 06 auto...... My problem is that whenever i put my car in D mode the car after sometime car does not move forward . Then i switched off my car for some seconds then start my car again and drive on mode D then again after 1 km it stopped and car does not move forward or reverse....Please help me with some good suggestion....mechanic told me the gearbox need to be replace....
Tags for this Thread
