Results 1 to 7 of 7
Thread: Cuore 06 Engine Maintenance
    faheem14's Avatar
    Mar 2011
    177
    Default Cuore 06 Engine Maintenance
    Dear Frds i have cuore 2006 which i have bought few months ago, it was showing decrease in engine oil so i went to toyota walton today for compression test along with tuning so before tuning the compression was 8 and after tuning it was 7. Plz advice wht to do? Car is nt Giving any serious problem now a days. Thks in advance
    driver_guy's Avatar
    Jan 2007
    37
    219
    Quote Originally Posted by faheem14 View Post
    Did they tell you whether the compression test results are normal or not?? They should have suggested something.
    btw how quickly is it reducing oil ??
    Here is the factory spec for Cuore's compression test. Your result should be within this range. ED-10 Engine
    Cuore 06 Engine Maintenance -376216
    sadiaali's Avatar
    Jan 2012
    563
    7
    5 Post(s)
    3 Thread(s)
    nice info by driver-guy,,,,,,,,,
    Search Rent Karachi on Facebook and Like it Please
    PKTUN's Avatar
    Oct 2011
    Khuzdar
    1,067
    35 Post(s)
    3 Thread(s)
    300 & 400 RPM means k engine is running ?? xulfiqar saheb iss par kuch roshni dalyeay
    driver saheb keya lahore mai aysay koi test kar sakta hai ???
    faheem14's Avatar
    Mar 2011
    177
    they said engine is weak and its reducing oil half litre after 3000 km.
    they dont do test like u mentioned. now what i do?
    rustam54's Avatar
    Aug 2006
    999
    113 Post(s)
    @Poster.
    Tuning has nothing to do with compression. Are you sure, the Toyota guys removed your plugs, and installed the following gauge to do the test??? And when you say 8 or 7, what unit are you considering--- kgf/cm3 or what???
    Cuore 06 Engine Maintenance - Compression Tester
    A car not giving serious problem does not mean that its fine in all aspects. The compression test (both wet and dry) tell which of the following are failing (or have failed) Rings, Valves or gasket.
    And if the figures you post are correct (in kgf/cm), then based on figures shared by driver_guy, i am afraid your engine is moving towards a point of rebuild that would start from rings minimum and further based on engine condition and your pocket as well. Please visit some other workshop or dealership if you still face the problem of oil reduction or reduce pickup.
    The Soul's Journey After Death in Islam (www.bit.ly/SoulsJourney) -- Originally Shared by kse101
    driver_guy's Avatar
    Jan 2007
    37
    219
    half litre after 3000Km is not alarming I guess. First try some basic things
    1- Check air block on intake ( usually mechanics block intake for CNG). Too much blockage can cause oil going out through blow by
    2- Try a better brand oil
    I dont always trust these toyota guys
