Results 1 to 5 of 5
Thread: brakes being hard of cuore when engine is off
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    Default brakes being hard of cuore when engine is off
    few days ago I went to murree. on road going down to GPO traffic was moving very very slow. I turned off engine of my cuore 2005 and used brake to go down when traffic moved after few minutes. I noticed that brakes became very hard but were working. but when I started engine, even in neutral brakes became light again. I noticed that when engine is off after applying brakes few times they become hard. is this normal or it is a problem? and if it is a problem where it is?
    Similar Threads:
    • #2
      Tabish1's Avatar
      Feb 2007
      3,068
      24 Post(s)
      It is normal !!
      As coure has Boster brakes!!
      Pakistan <3
    • #3
      yasirateeq's Avatar
      Jul 2012
      Rawalpindi
      12
      Default info about cuore
      HI,
      I have recently purchased a cuore 2002 ,it hit from bottom on some speed barkers if only two person are sitting on the back ,not to all but if they are bit high .One of my friend told me that it is due to CNG cylinder installed on the back .Please tell me that if it is normal or if not then what i have to get change(the springs or the shocks) in order to solve this problem.
      regards
      Yasir Ateeq
    • #4
      Vaqas1's Avatar
      Nov 2004
      5,267
      6
      49 Post(s)
      That is normal. Bcoz brake booster installed in your car needs vacuum to work and if engine is not running there is no vacuum for booster.
      Speed costs money, how fast can you afford to go.
    • #5
      meh1's Avatar
      Feb 2012
      Sahiwal
      1,361
      90 Post(s)
      thanks for reply with its underlying cause. As for cuore hitting speed breakers, mine one has high profile tyres. i.e 165 70 R12 instead of 145 70 R12 that are stock on 12" alloys. its body never hit even with 5 people on it. it also has after market CNG. and I have had no problems in suspension. I drive it with care and never cross 100. also you can carefully cross speedbreakers at an angle rather than straight. it will help. get spacers installed too. high profile tyres will help for sure.
