Results 1 to 13 of 13
Thread: Cuore ignition switch heating
    warewolf1's Avatar
    Jul 2009
    Other
    34
    374
    2 Post(s)
    Default Cuore ignition switch heating
    Hi guys. i have a cuore and its ignition switch was heating up very much. the key got hot too. the car also shut down a few times, i mean the current to engine was lost a few time. ignition switch wali wire ko chernay per current dobara on jata tha aur car chal parti thi. AC chalanay aur fan ko full karnay per ziada jaldi heat hoti thi taar. Electrician serviced the ignition switch and added relay to radiator fan. now the car is running fine alhamdulilah. the concern is: ignition switch ko janay wali wires (there are many, wrapped in nitto tape) kafi garam ho jati hain. koi problem nahin kar rahi car laikin aisa kyun ho raha hay? why are the wires getting so hot? any solution?
    How happy is the blameless Vestal's lot... The world forgetting, by the world forgot.
    Eternal sunshine of the spotless mind... Each prayer accepted, and each wish resigned...
    warewolf1's Avatar
    Jul 2009
    Other
    34
    374
    2 Post(s)
    Come on guys... no one has any clue?
    Sent from my HTC Desire HD using tapatalk 2
    shazaryab's Avatar
    May 2008
    52
    380
    You may have put extra load on your electrical wiring like heavy sound system , bigger radiator fan of AC condenser fan, More powerful headlight lamps ect.Drive all extra load items on relays.If not solved replace ignition switch with new.
    aqibasit's Avatar
    Apr 2008
    3,178
    30 Post(s)
    2 Thread(s)
    get ur ignition wiring checked,, its taking load
    Body kits available for all cars...
    PM for details
    warewolf1's Avatar
    Jul 2009
    Other
    34
    374
    2 Post(s)
    Quote Originally Posted by shazaryab View Post
    No extra load except higher watts of headlights... 90/100 I think... any idea of ignition switch price.
    Quote Originally Posted by aqibasit View Post
    The electrician said radiator fan and inner fan are taking load. Radiator fan is on relay. Ander walay fan k sath bhi relay attach ho jati hay?
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    i have a cuore too. I also have noticed that key becomes bit hot when AC and fans are on. just I feel that it is little hot. I have no relay on inner fan.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    the ignition switch controls current to the the ignition coil, blower, rad fan, and wipers and defogger when in use and the alternator exciter circuit - if they are getting hot then either its making poor contact or the wires are not capable of transferring such current, Are they repaired with twist tape???
    manobilla16's Avatar
    Oct 2008
    33
    123
    3 Post(s)
    same issue with one of our relatives car. They got the whole thing replaced from Toyota for 5K i guesss
    warewolf1's Avatar
    Jul 2009
    Other
    34
    374
    2 Post(s)
    Default Re: Cuore ignition switch heating
    What is twist tape?
    By the way, I went to a renown electrician today. He touched the wires and said, itni to garam hoti he hay yeh taar. Don't worry about it, It's nothing. Relay is already installed with radiator fan so just drive and let the wire be.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    is the wiring repaired?? most desi electricians dont bother soldering wires.
    warewolf1's Avatar
    Jul 2009
    Other
    34
    374
    2 Post(s)
    Wiring to repair nahin hui hui... Peechay se wires aa rahi hain aik connector main aur wo connector ignition switch k peechay fix ho jata hay. Last time connector change kiya tha aur ignition switch ki back walay points saaf kiay thay. Soldering kahan honi thi iss process main?
    Kissi had tak iss tarah ka setup tha jesa attached pic main hay.
  12. #12
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    the wires may get hot after a while - because they are very thin - however they wont cause a fire, If they are not jointed then dont worry about it - If you really want absolute cold wires then install a heavy duty ignition switch and redo the wires to thicker gauge. - MUCHO MONEY - spent for not much gain.
  13. #13
    warewolf1's Avatar
    Jul 2009
    Other
    34
    374
    2 Post(s)
    Thanks a lot Xulfiqar bhai... and aqibasit and shazaryab as well. Jazak Allah khaira for ur support.
