Results 1 to 6 of 6
Thread: Cuore Radiator Fan and Smoke Blow
    csi2130's Avatar
    Aug 2012
    Gujranwala
    19
    Default Cuore Radiator Fan and Smoke Blow
    Dear PakWheels
    I have two questions
    May i insitall a XLI double speed Radiator motor for better cooling og engine,Engine is over heated by AC on
    Second,i overhauled engine,there is white smoke when i start car in the morning and it disappeared as engine heated up after 10 or 15 minute later.Is it any problem?
    Thanks
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    cuore's radiator and fan are fully capable of cooling its engine and ac. check fan and valve operation.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3990 Post(s)
    94 Thread(s)
    6
    smoke when engine is cold is caused by bad valve seals - if its a fresh overhaul job then the mechanic might have torn the seals on installation.
    anyway - why did you choose the corolla fan. Its not that powerful.
    csi2130's Avatar
    Aug 2012
    Gujranwala
    19
    Dear ZRS,
    Thanks for ur input,pl advise me wht should be done now,is it dangerous?What do for valve seals now?
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3990 Post(s)
    94 Thread(s)
    6
    if its a fresh O/H job get to your mechanic and ask him to rectify this. And for radiator fan if you are upgrading use something like a SPAL, Bosch or Gate fan, Those things can literally move a tornado of air.
    Spartacus's Avatar
    Apr 2010
    26
    Xulfi bhai,
    The fan motor of my cuore burned out recently. Could u please recommend a replacement motor brand or any another substitute please.
    Much appreciated.
