Dear Pakwheelers.
I have cuore 2008,when i switch ON AC,needle is going to middle,after some time,AC would be tripped.It would happen in idle and in rushy area.When i drive on highway,then there is less problem.Fan is on direct
Second,cooling is not perfect,even i refilled the gas.
I have cleaned radiator
Used OSAKA coolant
But results are not so better.
I am thinking to install a small fan on the condensor,Is it possible to install a small fan on condenser?May any expert explain,how it will be installed and how it will be working?What is the cost of this installation?
May it give good results?
Thanks
Shahid
