Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By syedsarosh
Thread: cuore throttle link tilted, carburetor butterfly never shuts
    syedsarosh's Avatar
    Apr 2011
    74
    Unhappy cuore throttle link tilted, carburetor butterfly never shuts
    hello
    i was doin a check of carburetor as fuel efficiency decreased since my last setting months ago. cleaned its external links with brake fluid n brush, sprayed NASA carb spray inside, with proper instructions.
    while doing all this, i observed four irregular things.
    1. after dirt was removed, i saw the link where throttle cable ends, it was deshaped (tilted)... like some1 did it on purpose.
    cuore throttle link tilted carburetor butterfly never shuts -1038500
    2. the butterfly in the carb, is not shut at all, even at zero throttle.... however it opens further when throttle is increased.
    cuore throttle link tilted carburetor butterfly never shuts -1038501
    3. a rocker arm, connectd to pump sort of thing, leaked fuel if throttle is jerked.
    cuore throttle link tilted carburetor butterfly never shuts -1038502
    4. the hose out of carb base (probably engine) body, has water precipitates, and the hose connected to it is also shut at the other end with a blank, is it rite or some mechanic did it for his desi science
    cuore throttle link tilted carburetor butterfly never shuts -1038503
    the throttle link and the butterfly are connected as i figured it out ...
    but due to the throttle hinge tilted, teh rocker arm does nt force the spring mechanism of butterfly,
    and if i do the force manually, then the butterfly opens more, nt closes. so either a stupid mechanic dint set it properly, and could nt set the car bak at default setting ...
    plz tel ur point of view ... and how can i do the job at home ..,.
    i mean the butterfly should be shut by al means, at idle position?
    cuore also doesnt have a choke, so how the butterfly opens itself without the manual throttle by pedal?
    the hose under consideration (#4 point) should be shut like this or not?
    regards
  2. 28-12-2013, 03:46 PM
    Newbie
  3. #2
    nauman1000's Avatar
    Apr 2009
    Peshawar
    32
    49
    Default i can help
    if u still needs help i can help
    nauman1000@gmail.com
  4. #3
    faiz.aslam.121's Avatar
    Jan 2013
    Oslo
    21
    7,464
    5
    148 Post(s)
    4 Thread(s)
    Stahp bumping old threads. That guy probably owns a LC now lol!
    Turbo lag is like foreplay. You know it's coming. And it's gonna be good.
  5. #4
    kasper_341's Avatar
    Feb 2014
    hey man, very nice tutorial
  6. #5
    kasper_341's Avatar
    Feb 2014
    hello all
    can some please help finding "cuore carburetor" - and "point" i am looking for genuine parts.
    i called toyota capital motors for same info. (Plot # 405-406, 9th Avenue, Sector I-9, Islamabad
    Phone: 051 111-142-142, 051 4432027 - Fax: 051 4444631 - Email: cr@toyotacapital.com.pk)
    some lunatic answered the phone, didn't give any information and hung up on me ?!!
Tags for this Thread
