Results 1 to 17 of 17
Like Tree3Likes
  • 1 Post By fahadsoulsnatcher911
  • 1 Post By syedsarosh
  • 1 Post By asad1
Thread: Cuore don't convert on Petrol
    Heart_Break_Kid's Avatar
    Oct 2010
    26
    853
    Default Cuore don't convert on Petrol
    Hey Guys!,
    My Cuore is not converting on Petrol. It only converts to CNG and when Try to convert it to Petrol no lights come on switch not car start.
    Please Help
    I think I'm cute,I know i'm sexy,I got the looks,I'm just a sexy boy (sexy boy),I'm not your boy toy (boy toy),I'm just a sexy boy (sexy boy),I'm not your boy toy (boy toy)....
    masters1001's Avatar
    May 2012
    34
    82
    I also had the problem when i press first time it goes to neutral but it keeps running on CNG....even it still happens with me if i dont have the petrol .... after that i checked filling petrol and it responded in same way so i get checked n fuel pump was not working.
    Thanks
    Oct 2010
    26
    853
    Is there any wire in the engine bay that connect to fuel pump or some thing so I can check if the power is coming to it or not? Actually Last month I went to road side mechanic for cng setting and tuning . I am wnt to check if he forget to connect the wire or something?
    Oct 2010
    26
    853
    bump................
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    btw cuore has mechanical pump no power required and u should check petrol shut off switch which is located behind air filter blue color or black check the wiring u can check it it should make tik tik sound when switch on ur car on petrol
    Oct 2010
    26
    853
    It seems like my pertrol conversion switch is blown as electrician removed the switch joint the two wire with the help of small wire and car started on petrol. can any one tell me genuine (italian ) switch price for cuore? thanks
    fahadsoulsnatcher911's Avatar
    Jul 2009
    21
    2,876
    7 Post(s)
    Last week bought an original Landirenzo switch for my Corona for RS 450 (EFI)
    it should be around 100-300 not more than that btw the switch has a no written on it so before buying it confirm the no on the new and old one are the same
    Oct 2010
    26
    853
    Does any one have any idea on how to check if the petrol is not shut from the engine bay? Detail discription will be appreciated...
    syedsarosh's Avatar
    Apr 2011
    74
    hi..
    to chk the petrol..... in cuore ... when ur standing infront of bonnet, look at one fuel hose coming out from the bottom of the airfilter housing black chamber ... they will be comin out towards R/H of engine ... see image ... u can manually open the petrol valve, with the hook attached in red circle area... and by switch u mean the electronic module?Cuore dont convert on Petrol -1050296
    syedsarosh's Avatar
    Apr 2011
    74
    manual petrol shut valve is the only manual shut of petrol from engine bay ... if u want t see the serviceability of the fuel pump ... wwrongly written as fuel filter in image ... Juz open one of the two hoses coming out of the fuel pump ... and be sure its the output of the pump and nt the input .. as input is coming from the fuel tank ... open the output hose and put it into a bottle ... make sure no flames in the area and no spark .. .and then crank the engine and see if the pump throws fuel out ... if it does ... ur pump is working
    Oct 2010
    26
    853
    Thanks syedsarosh, ur help is really appreciated. I will check it tomorrow. By switch I mean the cng/petrol converter switch. It works perfectly fine on cng all lights comes. When I turned the button into petrol car shuts down but no light comes on the switch.
    Yesterday mechanic removed the wire grip from cng switch and with the help of small wire connected the first two wire and started the car started and it was on petrol as petrol smell conning from exhaust. And said switch is blown.
  12. #12
    Oct 2010
    26
    853
    I was not able to locate the valve which was indicated above. Attached the pic of engine bay, and the switch which has problem
  13. #13
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    it is right above the brake oil bottle with yellow wire u can check that switch directly by removing yellow wire and giving it + charge with battery it shud make tik tik sound remove the pipe from fuel filter from outlet to check whether the pump is working or not remove the pipe and start the car just give 2 3 round thats it u will get to know if its working or not
    if its not throwing petrol from outlet the fuel pump fault
    i will sugguest u to fix it ASAP as if the fuel pump diaphragm is leaked then the petrol might enter the engine which can seized engine
  14. #14
    syedsarosh's Avatar
    Apr 2011
    74
    Default hi
    Asad gave u the rite idea of checkin the switch (i.e. electric fuel valve)
    im mentioning the valve in ur pic ... look at it .. and also utilize the output of fuel pump to check, as i explained above. .and rather buy the switch from mkt and install urself in its place .. mechanic wil do the job and twist and turn something else, and finally decrease value of ur car in longer run... as they cant love ur car... (and i.e. cuore is heart in italian) Cuore dont convert on Petrol -1050939
    and also check the wire which reaches the oil level sensor, its losing its clamp... it is at the periphery of the chain cover at the left of air-filter black chamber
  15. #15
    syedsarosh's Avatar
    Apr 2011
    74
    the small red circle is a small linkage,, move it by hand and u can manually shut the petrol on and off
  16. #16
    Newbie Follow
    ghulamabbas.sap's Avatar
    Oct 2012
    same problem i am also facing can you help me for this or send me contact number.
    Thanks
  17. #17
    syedsarosh's Avatar
    Apr 2011
    74
    try opening fuel valve manually t chk... but gas muz b off from inside,,, pul its fuse or discnct wire ,,, or faulty fuel pump
