Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By qwertypoiu
Thread: Help Needed: Tyres for Cuore
    saadsmalik's Avatar
    Oct 2005
    25
    3,345
    4 Post(s)
    Question Help Needed: Tyre Size for Cuore
    Hi all!
    Its time the Cuore gets new tyres and I need a little help with the size.
    The car originally came with 145/70/R12. I currently have 155/70/R12 (10 mm wider and 14 mm greater in diameter)
    I'm planning to go for 165/70/R12 (because I don't think 165/65/R12 are available). These will be 20 mm wider and 28 mm greater in diameter.
    My question is, would there be any harm in going for this tyre size? Considering 165s will be 20 mm wider and 28 mm greater in diameter. Or if I can find 165/65/R12, would it be better to go for them instead?
    My height has stopped increasing, my width compensates for it.
    saadsmalik's Avatar
    Oct 2005
    25
    3,345
    4 Post(s)
    B u m p
    qwertypoiu's Avatar
    Feb 2007
    29,130
    153 Post(s)
    3 Thread(s)
    Shouldnt be a problem at all. rule of upsizing is155/70/r12165/65/r12175/55/r12this way your speedo will not give error. now when you will have 175/70 it till give error, you are going 70km as per speedo meter actually it will be 60. Well in short its not a matter of concern only make sure there is NO rubbing when steering is fully turned
    RIP
    qwertypoiu's Avatar
    Feb 2007
    29,130
    153 Post(s)
    3 Thread(s)
    Shouldnt be a problem at all. rule of upsizing is155/70/r12165/65/r12175/55/r12this way your speedo will not give error. now when you will have 175/70 it till give error, you are going 70km as per speedo meter actually it will be 60. Well in short its not a matter of concern only make sure there is NO rubbing when steering is fully turned.............
    RIP
    syedsarosh's Avatar
    Apr 2011
    74
    165/65/r12 can u plz elaborate as im low with tyre size knowledge ... 165 seems like tyre width .. wat r other numbers for ?
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    155/70 R13 is the best size for cuore with steel rims
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    And 165/65 R12 are easily available in dunlop Eco digityre btw i will not recommend them as they have bad tyre wall keeps on puncture
    saadsmalik's Avatar
    Oct 2005
    25
    3,345
    4 Post(s)
    Thankyou for the suggestions guys. Although I couldn't login for the past two days.
    Got 155/70/R12. Bridgestone B250.
    @syedsarosh
    155 is the width in mm.
    70 is the tyre wall size, as a percentage of the width. So in this case, 70% of 155 mm.
    12 is the rim size.
    @asad1
    I previously had Dunlop Digitire ECO. They did great (drove them 58,400 kms ). But all shops that I visited didn't have 165/65/R12. Everyone had 70.
    Site Banned Follow
    Goodnok's Avatar
    Oct 2012
    Kot radha kishan
    22
    yes he saying well, 155/70 R13 is the best size for cuore if having steel rims i have experienced these tyres with my coure
Tags for this Thread
