Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Naweed
Thread: sudden rpm increase on idling in cuore
    race_addicted's Avatar
    Nov 2008
    Rawalpindi
    36
    1,052
    4 Post(s)
    Default sudden rpm increase on idling in cuore
    Dear car gurus! i'm experiencing sudden increase in rpm while the car is on idling.. in desi language.. car jab starting haalat mein hoti hai tu race taiz ho jati hai.. Please tell me the possible reasons for this.. Regards
    faisal_giali's Avatar
    Jul 2006
    29
    83
    plz clean ur throttle body if ur car is efi
    Tabish1's Avatar
    Feb 2007
    3,068
    24 Post(s)
    Its Non-EFi
    Pakistan <3
    Naweed's Avatar
    Jul 2008
    50
    3,469
    12
    122 Post(s)
    3 Thread(s)
    auto choke could be the problem, or the jet in carburettor or the butterfly is getting stuck ... other far fetched ideas could be some vacuum pipe is loose or chocked or your accelerator wire is getting stuck .. i think these are, all the possible reasons fpr the problem
    "You have not lived today until you have done something for someone who can never repay you."
    geniesgona's Avatar
    Nov 2012
    Faisalabad
    28
    288
    5 Post(s)
    Its so Simple Clean Your Car Carburetor with Patrol. The Problem Will Be Resolve 100% tested in My Cuore. Because it has same problem 6 months ago Now its Fine.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    Your car should idle at above idle speed when the engine is dead cold - if you have removed the thermostat valve then it will do this as it can overcool and cause the system to work again.
