Results 1 to 7 of 7
Thread: Daihatsu Mira RPM Problem
    hello123's Avatar
    May 2009
    112
    3 Post(s)
    Default Daihatsu Mira RPM Problem
    Mira 2006 engine ef-se (660 cc) Solution for Following rpm problems requested
    when headlights on and car stops at signal or in P mode car stalls (rpm down engine vibrates than normal)
    when headlights on power windows used car stalls (rpm down engine vibrates than normal)
    someone told me to change butterfly valve/cap and throttle body clean
    Any expert suggestions
    hello123's Avatar
    May 2009
    112
    3 Post(s)
    bump ??
    hello123's Avatar
    May 2009
    112
    3 Post(s)
    refersh
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    Get the charging system checked first,Alternator might not be providing desired current.
    Never loose hope in life,every step gives u something.
    fahadwizz's Avatar
    Feb 2011
    35
    2,383
    52 Post(s)
    3 Thread(s)
    Looks like an alternator problem. Its jamming up on load.
    hello123's Avatar
    May 2009
    112
    3 Post(s)
    can someone refer any good electrcian in rwp isb
    jz
    jz is offline
    jz's Avatar
    Dec 2004
    26,106
    5
    185 Post(s)
    12 Thread(s)
    u need to upgrade ground wires n seems like the voltage is low in ur car
    a potential cause can be a weak generator
    www.facebook.com/performancepartslahore
