Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By shabd
Thread: Where to get CNG advancer/retarder for cuore
    naveed_sid's Avatar
    Nov 2008
    35
    39
    Question Where to get CNG advancer/retarder for cuore
    My cuore engine is knocking on petrol. I think it needs advancer/retarder as the CNG is not company fitted.It is a lendirenzo CNG kit.
    I am not able to find an advancer/retarder in the market anywhere.Please suggest.
    fahadwizz's Avatar
    Feb 2011
    35
    2,383
    52 Post(s)
    3 Thread(s)
    Just retard the timing a few degrees from the distributor. You can also get it set at factory from someone who has a timing gun.
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    Quote Originally Posted by naveed_sid View Post
    Contact to any lendi renzo franchise.
    Never loose hope in life,every step gives u something.
    naveed_sid's Avatar
    Nov 2008
    35
    39
    Where in karachi is the landirenzo franchise?
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    LR PAK Pvt. Ltd
    C-11, S.I.T.E Industrial Area, Karachi, Pakistan
    Phone: +92-213-2550031-32
    Fax: +92-213-2550033
    www.lrpak.com
    naveed_sid's Avatar
    Nov 2008
    35
    39
    Sir,
    I found the original cuore retarder Landirenzo STAP 00 (Platinos) kabli or used one
    It has a connector with six connections but the wire has 5 connections.AEB is written on wire.
    the connections usually shown on pakwheels in images have 6 wires so how will i connect these 5 wires.
    Cuore ownrs please check your connections, do the advancer also has 5 wires?
    and how to connect these 5 wires?
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    1 - Red wire to ignition coil +ve wire terminal.
    2 - Black wire to battery -ve or body ground.
    3 - Blue wire to blue wire of solenoid valve attached with cng regulator.
    4 - Remove brown or green wire attached to -ve terminal of ignition coil and connect white wire to -ve terminal of ignition coil.
    5 - Connect brown wire to wire (Brown or green ) removed from ignition coil's -ve terminal.
    alee1's Avatar
    Oct 2009
    Wah cantt
    27
    1,998
    12 Post(s)
    advancer is used in efi cars only cuore aint efi, its a carby car and u need to rotate distributor to advance it
    mAin tE h0nDa hE lAisAn...
    afarooqi's Avatar
    Jul 2006
    38
    916
    20 Post(s)
    Sir,
    Kahan say mila bhai
    Prepare for the worst, Hope for the best.
    naveed_sid's Avatar
    Nov 2008
    35
    39
    I have fitted the retarder but it seems it needs setting on petrol from STAP 00B.
    It has a register (screw) beside the wire connection.
    Please tell me that to retard turn the screw clockwise or anti-clockwise?
    Experts please reply soon.
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    First of all set the ignition timing by rotating distributor on cng,then convert the vehicle on petrol, you will have to use timing light for proper setting,some times screw needs to turn clockwise & some times it needs to turn anticlockwise.
  12. #12
    siraj_7's Avatar
    Jun 2012
    465
    10 Post(s)
    Asalamualikum, if you have installed this in your Carbi Cuore then it must also be possible to install this on carby khyber...I heard some one also installed stap 00b on their khyber. Is it possible to meet you and see your ride and learn how to do it...I am also in KHI
  13. #13
    shabd's Avatar
    Aug 2009
    Rawalpindi
    179
    i have purchased this from local electrician in rawalpindi, box and wiring, fitted in my 2006 crby cultus, this is working fine. timings are now 10 on petrol and advanced automatically on CNG to 20. working very fine
    Sheikh Abdullah 03005081740
  14. #14
    mehmood157's Avatar
    Nov 2005
    Rawalpindi
    38
    14
    Hello brotherens ..... I have got Cuore CX ECO and surprisingly I found last night that it is fitted with LandiRenzo Timing Advance Processor ..... I was setting my ride on petrol as after setting from different mechanics I was having only 7-8 Km/l ...... I am still not sure after reading this ......
    How to Adjust a Carburetor: 23 Steps (with Pictures) - wikiHow
    Are there two screws for adjusting petrol and air in cuore (as mentioned in above link) or I have to adjust a sawtooth shaped screw .... I have only found this screw on lower backside of my carburetor ....
    Also I want to ask how can I confirm that my TAP is working fine ...... ????
    Please comment ...
Tags for this Thread
