Results 1 to 9 of 9
Thread: Loss of power in Cuore
    The_lasting_impression's Avatar
    Jul 2009
    Rawalpindi
    43
    197
    6
    Default Loss of power in Cuore
    I have Cuore 07 with 120,000 running. There is blow by in the engine and also the engine oil decreases. But there is no smoke from the tail pipe in the morning cold start and still water drops come out. My cuore used to do 130 km on straight roads on CNG but now it doesn't go beyond 120. I've got it tuned by many mechanics but i feel loss of power. What may be the possible reason and what is the right solution??
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    This is an indication of compression lost,It could be because of weak compression rings or leaky valve.
    Never loose hope in life,every step gives u something.
    aqibasit's Avatar
    Apr 2008
    3,178
    30 Post(s)
    2 Thread(s)
    If there is no smoke from tail pipe then it cud b leaked seal.. Speed is not the scale for measuring engine health
    Body kits available for all cars...
    PM for details
    faizandawood007's Avatar
    Jan 2012
    Gujranwala
    25
    2,566
    33 Post(s)
    5 Thread(s)
    You have said quite a lot about the problems of car and u still think that u can get 100% from the engine ur engine is getting weaker and weaker...
    Can,t think of a better signature
    Jul 2009
    Rawalpindi
    43
    197
    6
    Quote Originally Posted by argtr65 View Post
    I don't want to overhaul it's engine right now. How can i stop blow by or reduction of engine oil??
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    Quote Originally Posted by The_lasting_impression View Post
    Avoid over speeding and use high viscosity oil.
    ihsannissan's Avatar
    May 2012
    Peshawar
    156
    5 Post(s)
    the only solution is to overhaul, only Rings, Piece, and also change Valves.
    if u still not happy with this,
    then use ZIC oil change it after every 1500 km
    Deemy1's Avatar
    Aug 2004
    35
    7
    your comperission ring is weak..after 120,000k.m you need to overhaul engine..if you don't want it right now just change rings and valves..
    if either not want to change rings just use zic oil and turn your timing to advance at 14-15 degree..by doing this you get more pickup and speed..
    fahadsoulsnatcher911's Avatar
    Jul 2009
    21
    2,876
    7 Post(s)
