Results 1 to 5 of 5
Thread: Hard brake pedal Cuore
    ToxicDevil's Avatar
    Nov 2010
    1,318
    15 Post(s)
    13
    Default Hard brake pedal Cuore
    The hand brake does 3-5 click and the brake shoes were also replaced a few months back.
    When you press the brakes/ when the brakes are engaged the pedal feels very hard or you can say that you have to use a lot of force to get the desired braking.
    I usually drive civic 6th gen so I am comparing the brakes of two. So I dont know if there is a fault or not.
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    dont compare it with civic
    its pretty normal in cuore
    aftababc's Avatar
    Jan 2013
    419
    3 Post(s)
    Break lines ma air aa gae ho ge ya phr break piston ring faulty ho gae honge>
    ap front break pistons ke service karwa lain .plus ring new dalwain kaam fit hojayga insh allah
    aftababc's Avatar
    Jan 2013
    419
    3 Post(s)
    Quote Originally Posted by toxicdevil View Post
    the hand brake does 3-5 click and the brake shoes were also replaced a few months back.
    I usually drive civic 6th gen so i am comparing the brakes of two. So i dont know if there is a fault or not.
    50 pkr ke ring mil jate ha aik 1 saal pehly ki baat hai
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by ToxicDevil View Post
    I believe the correct setting is about 6 clicks on the handbrake lever and the automatic adjusters should work by themselves afterwards, You should change the brake fluid completely, takes a small pipe and jar, dont press the pedal to the floor, press is halfway only. if you press it to the floor you may rip the piston seals as it goes into unmaintained area of the master cylinder which usually rusts out because the brake fluid is not changed in time.
    Make sure to keep the catch jar above the level of the bleeder valve to ensure no air bubbles can back into the system.
