Page 101 of 156 FirstFirst ... 519199100101102103111151 ... LastLast
Results 2,001 to 2,020 of 3117
Like Tree943Likes
Thread: Cuore Fan Club
    bilal740's Avatar
    Dec 2005
    29
    47
    Default Cuore Fan Club
    HI to all coure owners here u can post qualities of ur car compare to other its compititers like ,mehran, alto etc,,,
    (heading edited by admin/mods - spelling mistake)
  2. #2001
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by usmanuetian View Post
    Reply frm harib4u is perfect.
    Had same issue few years back, toyota walton wala mechanic did same and it was water pump noise, so got that changed.
    Original waterpump was of 5500 while japanese was 2000 I think. Just for ur info.
    Are u using tap water in cooling system instead of coolant
  3. #2002
    usmanuetian's Avatar
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    Quote Originally Posted by saboor73 View Post
    was using tap water till last year. then changed to zic coolant.
    using a good quality coolant is a must.
    Leave sooner, drive slower, live longer
  4. #2003
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    Quote Originally Posted by mani001002 View Post
    Abhi insha allah toyota walton sa tune kra k jioun ga
    yes you can visit them. tuning charges are 600.
    if you are planning to go on saturday, go early, since sat is a v busy day for almost all dealerships.
  5. #2004
    mani001002's Avatar
    Oct 2014
    Rawalpindi
    38
    190
    7 Post(s)
    Insha allah
  6. #2005
    raxaengineer's Avatar
    Jan 2012
    Okara
    197
    2 Post(s)
    Advantage: none
    Disadvantage: less amount of zddp for flat tappet engine
    Sorry i can't understand plz explain
  7. #2006
    midreestaj's Avatar
    Jul 2012
    223
    22 Post(s)
    Advantage: none
    I was reading on ZDDP (zinc and phosphorous) and found it was introduced by Castrol. ZDDP usage was lowered after 80s as it caused to kill the catalytic converter sooner. On the other hand, modern oils do have other additives to reduce the wear on flat-tappet camshafts such as ester, molybdenum and boron as generic additives and designer additives which are respective to their innovators such as Magnatec or Tehcron etc.etc. using marketing terms on souped up chemical derivatives of these generic additives.
    Also it seems ZDDP becomes more important on flat-tappet cam engines when they are in break-in period or newly over-hauled. there is a lot of discussion over the internet on it.
  8. #2007
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by midreestaj View Post
    Boron,ester & molybdenum are friction reduction additive they aren't as effective as zddp that the reason zddp is still present in oil as anti wear agent
  9. #2008
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by raxaengineer View Post
    Your cars engine is of very old design and face more wear and tear you need engine oil with more anti wear anything that says api sm/an is not recommended for your engine and anything that says api SG/sf/sh is good for your car
  10. #2009
    midreestaj's Avatar
    Jul 2012
    223
    22 Post(s)
    ZDDP is also cheaper than the modern additives therefore they are present in old school oils. Such as SG rated old spec oils. It is also present in SM/SN but the quantity is lower to make it meet the green specs. Usage of older oils in older engines help to save cost but I doubt it is hazardous as if it was there would be many rocker arm engines with grinded cams as a result.
    Check the response of Castrol on the subject. http://www.ahcso.com/pdf/response_to...om_castrol.pdf
  11. #2010
    wasf's Avatar
    Dec 2007
    38
    545
    36 Post(s)
    I want to know what is difference between cuore cx & CL ECO variants?which models are AT or MT? If I get 2003-4 model cuore is it better choice then mehran?
    Sent from my Z10 using Tapatalk
  12. #2011
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    Quote Originally Posted by wasf View Post
    I think CL variant was originally without AC and having black bumpers (im not sure).
    CX will be a petrol and AC with matching bumpers.
    ECO means u can say CNG.
    You didnt mention manufacturing year for mehran.. but if that 2003-4 coure is a clean one, then its much better than mehran.
  13. #2012
    Jan 2012
    Okara
    197
    2 Post(s)
    Recently visited islamabad muree ayubia patriata etc and done almost 900 kms on my cuore within 3 days. Now i am facing missing problem in coure. Like patakha on sudden excilrator. I have to go back okara now. What should i have to do.?
    Before starting my visit i had done oil change and tunning. Pl suggest me best option without mechanic interference.
  14. #2013
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    @meh1
    plz reply
  15. #2014
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    @meh1
    plz reply
    i has this problem in my cuore twice. once it was solved by changing air filter and once after tuning and oil and filters change. I had this mainly on CNG and i believe it happens when car needs tappet setting.
  16. #2015
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Go to any mechanic ask him to loose tappets a bit
  17. #2016
    Maverickiz3d's Avatar
    Jun 2010
    32
    554
    12 Post(s)
    Clear your PM sir.
    (sorry for offtopic)
  18. #2017
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by Maverickiz3d View Post
    Clear your PM sir.
    Sorry for trouble cleared now
  19. #2018
    faizan.f7's Avatar
    Jan 2014
    95
    Guys, I want to change engine oil in my cuore on my own for the first time.
    Can anyone help me with the pictures of the whole process with the draining out procedure as well. And which oil shall I use?
    Thanks in advance!
  20. #2019
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    Quote Originally Posted by faizan.f7 View Post
    Thanks in advance!
    ok, first of all get total/shell/caltex 20w-50 oil. after a trip when engine is hot, remove oil drain plug and drain. remove old filter, remove cap from new pack of oil. fill cap with oil. from cap apply oil to filter's rubber seal and pour rest inside new filter. clean filter's place with cloth.(mechanics dont do it) place filter and tighten with hand. pour new oil inside and its done.(pour only 2.25 and check level and make it till F mark) mechanics pour 2.8 which is too much)
    take lot of care when draining. i got it spilled on floor twice and it was a pain to clean.
    i dont have photos for now but if anything is not clear i will make it clear with photo.
  21. #2020
    faizan.f7's Avatar
    Jan 2014
    95
    Quote Originally Posted by meh1 View Post
    Sir, Its so nice of you to explain in detail. But as I told you I am doing it for the first time If I can get the pictures of the oil filter and place of drain plug. I would be really grateful.
    And one more query, actually I have auto cuore, I usually drive it alone. But when sometimes my family or friends came along and If the car has 4 people, Its soo heavy to drive. Its on CNG.
    What could be the reason and how can it be resolved?
