Page 110 of 156 FirstFirst ... 1060100108109110111112120 ... LastLast
Results 2,181 to 2,200 of 3117
Like Tree943Likes
Thread: Cuore Fan Club
    bilal740's Avatar
    Dec 2005
    29
    47
    Default Cuore Fan Club
    HI to all coure owners here u can post qualities of ur car compare to other its compititers like ,mehran, alto etc,,,
    (heading edited by admin/mods - spelling mistake)
  2. #2181
    Newbie Follow
    rafay.moeen's Avatar
    Aug 2015
    Default Cuore foundation
    Hi, please tell me how many foundations are in a cuore and how much do they cost? I have a 2003 cuore (first owner) and it has started making sounds when i accelerate in first gear.. A person at shah jee said that it is due to your foundation that engine is touching it
  3. #2182
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    Quote Originally Posted by usmanuetian View Post
    Auto off means, ask petrol guy for full tank and ask him to stop when the petrol gun stops automatically. Run ur car for say 100 150kms then fill again with same method. Then simply divide kms by the petrol filled for that trip. That would b accurate avg.
    There may be some leaking in radiator or related pipes. Get it checked frm some expert mechanic. @meh1 can guide much better. Keeping fan direct is not advisable.
    if head gasket is fine, radiator is good and there are no leaks, then there should be no water loss. are you using coolant or plain water?
  4. #2183
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    Quote Originally Posted by rafay.moeen View Post
    cuore believe cuore has 3 foundations. at local stores it costs 500-700/piece for new/kabuli. at toyota it is expensive.
  5. #2184
    usmanuetian's Avatar
    May 2008
    Sharjah
    31
    3,733
    67 Post(s)
    3 Thread(s)
    Quote Originally Posted by meh1 View Post
    Yes there should b no water loss if things r working fine.
    Im using coolant, zic
    Leave sooner, drive slower, live longer
  6. #2185
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    i was about @wasf. i know your cuore has no cooling system problem.
  7. #2186
    wasf's Avatar
    Dec 2007
    38
    545
    36 Post(s)
    Mostly water.when radiator was serviced then some Rs 150 coolant was filled but after that mechanic had to open head to change gasket & all coolant was lost.After that it is simple water I refill when it becomes low.
  8. #2187
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    Quote Originally Posted by wasf View Post
    water evaporates faster. for now try to use any cheap coolant. and when it is stable use caltex/zic/toyota coolant.
    direct fan is good at hiding problems in cooling system. I have seen that auto cooling best works with new and not damaged radiators. a repaired radiator will start to leak again when it is under pressure. and with direct fan, Neither there will be heat not pressure. and little amount of coolant leaking evaporates due to fan working so you can't see it leaking.
    anyway I will remind you few more disadvantages of direct fan: in addition to extra load on alternator, wiring becomes hot when fan runs for long. and eventually wiring is useless. then electrician will make money by making wiring a mess. using high current fat wires and nitto tape
  9. #2188
    wasf's Avatar
    Dec 2007
    38
    545
    36 Post(s)
    OK I will refill again Kemo coolant Rs 150/bottle. On old engines mechanics insist to get fan direct.To have auto fan engine should be in good condition & wiring should be neat & properly done too but in my engine wiring is messed up,looks like a forest.OR may be a professional qualified electrician,mechanic should do neat,proper wiring to ensure thermostat is functioning accurately.
    Can water loss be due to replacement of non genuine head gasket OR gasket isn't sitting properly there?when engine heated up fan was on auto then as it was winter so gasket was replaced,fan made direct for summer season, I asked mechanic for genuine but he said no need of genuine,it is old car.
  10. #2189
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    non genuine head gasket of good quality and installed properly works fine. but where not installed property with engine working, gases go in coolant under pressure heating it and suck water into engine(with piston movements). if you coolant is oily and when you open cap with engine running, you see bubbles coming up constantly, implies a bad gasket.
  11. #2190
    wasf's Avatar
    Dec 2007
    38
    545
    36 Post(s)
    When buying old car some people suggest to check for condition of body,floor for rust etc & don't consider the condition of engine saying engine can be overhauled or new engine can be installed in 15-20K but now I see such thinking isn't right.Engine replacement needs documentation of new engine in registration book plus value of car decreases.
    My problem now is car engine has many issues.One good thing is it don't reduce oil.One mechanic told me car mixes oil with water which is a sign of bad engine.Also when accelerating & radiator cap opened the water is thrown out which isn't a good sign,i asked mechanic he said old engine behave like this.
    There comes few bubbles occasionally in radiator water when I observe it but I think they aren't too much.
    Naweed & dayrider have told about two mechanics in Pindi I will have to visit them, get list of all work to be done & get estimate & then get work done time by time according to the list.
    About wheel heating problem,some days ago I get car washed& when it was raised I rotated both front wheels,left moves freely & better then the right wheel and rotated for longer duration while right rotates for less time.Right wheel was heating up when it's caliper was changed & finally master cylinder was changed,still right is more hot to touch after my daily drive of 20KM but I am afraid too it may cause problem again on a long journey.
  12. #2191
    awaisamjad1's Avatar
    Jun 2015
    23
    17
    Default Top speed of cuore
    Can any body tell the top speed he ever experienced on cuore .?
    Manual and Auto both with stock equipments?
    I want to purcHase this car for motorway travelling with one or two persons only i drove a cuore a friend of mine's .
    That cuore manual -2008-850cc-in strong condition
    hit only 127km/h not going ahead
    Is it only its top speed?
  13. #2192
    May 2008
    Sharjah
    31
    3,733
    67 Post(s)
    3 Thread(s)
    Quote Originally Posted by awaisamjad1 View Post
    For u 127kmph for coure is "only" 127kmph ????
    And why do u want to achieve max speed, its a small car not built for speed. More is the speed, more is the car unstable.
    Though once long time back i watched a vdo on utube, someone achieved 140 on coure on motorway. That may b a new car...
    Speed thrills but kills...specially in a small local built car...
    Stay safe
  14. #2193
    Rustle's Avatar
    Jun 2012
    522
    22 Post(s)
    Back in 2013 my cuore 2005 touched 150 with ac and 160 without ac! It was in an immacculate condition..
  15. #2194
    xiddiqui's Avatar
    Jan 2014
    Smile front hub assembly
    Quote Originally Posted by mani001002 View Post
    Fornt and rear shocks work done after 1year 4 months from rafique shock specialist opposite koha noor mill near phir wadhai rwp
    Front shocks repair + spring changed
    Rear changed with kabli shocks
    Total amount paid 3600/-
    Now 100% satisfied car is smooth
    Dear
    Can you please let me know the exact location or cell number of that mechanic, in fact i have some work with my cuore with front shocks and hub assembly needs to be replaced, i tried different mechanics but in vain, very much sick of these stupid mechanics.
    please let me know if your mechanic is good.
    jazak Allah khair
  16. #2195
    May 2008
    Sharjah
    31
    3,733
    67 Post(s)
    3 Thread(s)
    Meeting my love after long time....😜😜
  17. #2196
    fezan.x's Avatar
    Nov 2013
    27
    104
    2 Post(s)
    127 is not "only" for this small car
    Btw for your question, I have driven my Coure Manual (2007) max 131km/h on petrol (with ac) on M9 (road is a nightmare) and average top speed on cng i achieve is 110-114km/h (with ac)
  18. #2197
    ali.7861's Avatar
    Jun 2014
    2,135
    44 Post(s)
    I had the Same Colored Cuore which got stolen 2 year ago and Till Not Found !!!
  19. #2198
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    Quote Originally Posted by abc1111 View Post
    sorry for your loss. how it happened?
    anyway should never leave your car alone outside. Once I went to islamabad and parked cuore outside hotel. I kept looking at it every hour and then eventually at 3am slept in car
  20. #2199
    ali.7861's Avatar
    Jun 2014
    2,135
    44 Post(s)
    Heppend at between 11 to 12 o clock at the night car was parked near the apartment at the morning i was about to go nearby Juice Shop but car was not there !!
    That was the 1st time in my and my father's that Our Car got Stolen !!
    Such cars like coure mehran and Corolla are Hot Cake for theifs !!!
    year ago i've Bought a Swift !!
    But i still wish that we found our cuore back !!
  21. #2200
    May 2008
    Sharjah
    31
    3,733
    67 Post(s)
    3 Thread(s)
    may u recover ur loss soon.
    normally i always keep an eye on car, and using clutch bar from last year, which is quite a mental peace atleast for me.
