Page 144 of 156 FirstFirst ... 4494134142143144145146154 ... LastLast
Results 2,861 to 2,880 of 3117
Like Tree943Likes
Thread: Cuore Fan Club
    bilal740's Avatar
    Dec 2005
    29
    47
    Default Cuore Fan Club
    HI to all coure owners here u can post qualities of ur car compare to other its compititers like ,mehran, alto etc,,,
    (heading edited by admin/mods - spelling mistake)
  2. #2861
    midreestaj's Avatar
    Jul 2012
    223
    22 Post(s)
    Quote Originally Posted by aliraza450 View Post
    Bro fan is working and and radiator is also serviced I guess I should change the radiator. Which radiator should I buy
    Sent from my XT907 using PW Forums mobile app
    Just get a new radiator bro with dual columns .. copper is better choice and check your water pump too
    Drain all water and fill again and drain. Repeat it 2-3 times before adding new coolant in the new radiator.
  3. #2862
    aliraza450's Avatar
    Jul 2014
    191
    Quote Originally Posted by midreestaj View Post
    Thanks bro
  4. #2863
    wasf's Avatar
    Dec 2007
    38
    545
    36 Post(s)
    @Xulfiqar @capsat @meh1 @midreestaj @dayrider @margallar @Naweed & all respected members ‎
    From last 2-3 days I am facing a problem car engine turn OFF while in mid of a road or street,once it happened in 3rd gear.i changed carburetor with a qabli & distributor with qabli electrical & ignition coil too couple of weeks ago.After turning OFF it starts at very next sulf without problem.Sometimes another problem occurs like engine turns off suddenly after starting of sulf- it happens 2-3 times & then it starts OK.There are no other issues like jerks, missing.i spoke with 2 mechanics about it,one even took a test drive but this problem didn't occur then so he told he can't say anything untill it happens in front of him,other mechanics told me that my driving style may be wrong leading to engine turning OFF.According to mechanic carburetor, race settings etc are fine according to engine noise & exhaust smoke.This problem happened so far only when I was driving with AC OFF.‎
    Also I will get new complete wiring of my car soon as old wiring is in bad condition, all messed up, too many joints ,neto tapes used- After a new wiring it will be easy to sort out any problems happening
  5. #2864
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,587
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    @wasf contact @margallar - at a reason able fee he can fix the car wiring better then ANY professional sidewalk tin box electrician.
    the problem seems to be failure of electrical, sort it out before you decide to get any mechanical work done
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
  6. #2865
    dayrider's Avatar
    Mar 2006
    27
    1,895
    5
    16 Post(s)
    2 Thread(s)
    Quote Originally Posted by capsat View Post
    1+
    Sent from my HTC One using PW Forums mobile app
  7. #2866
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    causes that come to my mind that can cause bad idle are faulty fuel pump, leaking vacuum and need for tappet adjustment.
    Quote Originally Posted by wasf View Post
  8. #2867
    wasf's Avatar
    Dec 2007
    38
    545
    36 Post(s)
    Sure Sir.I contacted him told him about wiring problems.I will get It done by him when I will go to islamabad on next visit.
  9. #2868
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,587
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    update the thread when its done. before & after pictures
    @margallar you please use camera for BEFORE & AFTER ..
  10. #2869
    wasf's Avatar
    Dec 2007
    38
    545
    36 Post(s)
    Quote Originally Posted by meh1 View Post
    Sir will we call it bad idle when engine turns OFF right after starting with sulf ,it happens 2-3 times but then problem disappears.Other problem Is engine turning OFF while car is runing.somebody told me it can be due to coil not having proper earth so missing spark-i remember when coil was replaced with qabli then electrician tried to connect earth wire but it was sparking so he connected coil without earth.I am suspecting too that ignition switch is faulty too.I will get help of margallar for all these electrical issues soon.
  11. #2870
    margallar's Avatar
    Oct 2009
    9,957
    6
    283 Post(s)
    4 Thread(s)
    start the car in a dark place and look for hanky panky near the igniton coil, while the engine is running
    haters gonna hate, potatoes gonna potate
  12. #2871
    margallar's Avatar
    Oct 2009
    9,957
    6
    283 Post(s)
    4 Thread(s)
    i missed something, ignore the above post
  13. #2872
    wasf's Avatar
    Dec 2007
    38
    545
    36 Post(s)
    Quote Originally Posted by margallar View Post
    Ok.i think I still should look for any sparks arrising from coil or wires in dark.
  14. #2873
    raxaengineer's Avatar
    Jan 2012
    Okara
    197
    2 Post(s)
    bro i have 2006 cuore having serious issue. please help me.
    1 week pehly thokar k pas meri front lights ki wiring burn ho gai thi so mein ny new wiring krwai means fron tubes wires relays replace krwai or ab lights use ki to battery dead ho gai next day mein ny battery new lagwai last night ous battery ki chargiing b khtm ho gai. mein bht ziada preshan hun k msla kya hy let me guide plz by experts. or han kbi kbi lights high low b ni hoti bs 1 jga he rehti hein or aahista aahista lights dim ho jati hein or horn b kaam chor jata hy i am waiting for your quick response.
  15. #2874
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    Either your generator is not working or it is not connected.
    Quote Originally Posted by raxaengineer View Post
  16. #2875
    Jan 2012
    Okara
    197
    2 Post(s)
    Generator agr na kaam kry to mere khyal sy generator ki light chly ya fir car start krny sy horn or light b ni chalni chahiye
    Sent from my SCH-I545 using PW Forums mobile app
  17. #2876
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,587
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    @wasf
    it is Starter Motor - not SULF / SELF
    self-start was a marketing FEATURE of vehicles started 1911 forth
    Before that an starter rod as in jack rod was inserted into the crank pulley and rotated to start the engine. 1896 saw the first electrical starting car,
    later technological development in 1911 by DELCO /BENDIX USA put forth the SELF-START as feature in the cars by using a starter motor which was a leap forward since then no looking back
    like many of you have no clue of rotary dial phone set & a manual typewriter with single font
  18. #2877
    sajidahmed's Avatar
    Sep 2007
    672
    3 Post(s)
    Once i I had the same issue and fool around by technicians and replaced a good battery, problem still persist, finally it was diagnosed that the plastic connector near battery is losses inside and burnt. I cut the battery wire from that connector and make a direct hard joint and this resolve the issue.
  19. #2878
    sajidahmed's Avatar
    Sep 2007
    672
    3 Post(s)
    Dear fellows need advice for a break issue in coure.
    Front break are making grinding sound on breaking and some time tuck tuck sound on pressing break lightly, on full press the sound is minimum.
    - Pads are replaces
    - disc is re surfaced
    - tyre changed and balanced with alignment
    - all hydroloic tubes are properly inspected they are on there runway
    - shocks look ok
  20. #2879
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,587
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    clipper pins needed silicon grease. Goto Jamil autos 0300 9232821 request for diagnostics and clipper pins / piston lubrication using silicon lube
    Quote Originally Posted by sajidahmed View Post
    - Pads are replaces
    - shocks look ok
  21. #2880
    sajidahmed's Avatar
    Sep 2007
    672
    3 Post(s)
    Thanks, are they in Karachi?
    Location?
