Page 145 of 156 FirstFirst ... 4595135143144145146147155 ... LastLast
Results 2,881 to 2,900 of 3117
Like Tree943Likes
Thread: Cuore Fan Club
    bilal740's Avatar
    Dec 2005
    29
    47
    Default Cuore Fan Club
    HI to all coure owners here u can post qualities of ur car compare to other its compititers like ,mehran, alto etc,,,
    (heading edited by admin/mods - spelling mistake)
  2. #2881
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,587
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    shahrae quaideen signal at kashmir road junction, area called khudadad colony
    Quote Originally Posted by sajidahmed View Post
    Thanks, are they in Karachi?
    Location?
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
  3. #2882
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,587
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    few of this forum member have tested them and seems like they are fine n better compared to others
  4. #2883
    sajidahmed's Avatar
    Sep 2007
    672
    3 Post(s)
    @capsat
    thanks, I will contact him soon, yes I had seen that area, in fact not too far from my home.
  5. #2884
    wasf's Avatar
    Dec 2007
    38
    545
    36 Post(s)
    Tonight again engine turned off while I was driving on road in 3rd gear so I parked car in dark area to check for sparks & I saw Continous sparks (yellow color) on coil side where lead is connected & on top body of coil.qabli coil was checked at shop before buying. sparks arise when ignition is started & keep arising continously when engine is runing.when electrician was installing this qabli coil I insisted to connect earth wire too,he tried but connecting wires with body was giving sparks so he didn't connect it.
    Updated : in morning I started car & some noise was coming tac tac i opened bonnet & saw a plug cable was detached at distributor side.Few days ago coil cable was detached on distributor end & car wasn't starting but this time car started but giving noise.Now this has happened twice,what can be cause?engine vibration or loose cable ends etc causing cable to detach?car was parked in secure place at night so it is sure nobody played with it.when I bought qabli distributor shopsman said old thick cables will fit on it easily & they are fitted easily but still they fall out
    Cuore  Fan Club - 08859eac08bff2102c4b0ffd1d097b1b
  6. #2885
    wasf's Avatar
    Dec 2007
    38
    545
    36 Post(s)
    After changing distributor to qabli electrical my plugs,coil cable comes off where they are attached with distributor cap.cables are thick type like Cuore genuine cables,only coil cable was changed sometimes ago.do they become slippery maybe from oil when distributor was installed? What should I do?first try to clean ends if there is any oil causing them to slip out or replace cables.mechanics say 2 out of 3 cables are genuine & in good condition.One cable has burnt rubber near spark plug engine side
    Cuore  Fan Club - 6bf8dfc2453c5276ef77b915a6a63b5a
  7. #2886
    hassantahir2's Avatar
    Mar 2016
    Faisalabad
    22
    812
    17 Post(s)
    Quote Originally Posted by wasf View Post
    The best bet would be changing the cables with brand new one's instead of used or kabli one's. Mostly used or kabli parts have completed their life like these.
    Check for the resistances of the plug wires and if the values exceed the required values given in manual of the car then they definitely need replacement.
    The aftermarket wires may cost you around 600-1200-/RS for a normal new set. They also work good.
    I am using the ultima plug wires in my car from 3 year's till now they are going good no arcing or loosing of cable's from distributor end/ignition coil/spark plugs.
    The OEM wires must be really expensive.
    @margallar has faced the issue of arcing on ignition coil he would guide you better about that.
    Sent from my D2502 using PW Forums mobile app
    Four wheels move the body
    Two wheels move the soul
  8. #2887
    wasf's Avatar
    Dec 2007
    38
    545
    36 Post(s)
    @hassantahir2 are ultima 8mm silicone wires? Are they better then those available in market in 600-1200 as you mentioned?once I found price of USA A1 quality made silicone 8mm wires cost Rs2200.I am planing to go to margallar for all these electrical issues of my car.
  9. #2888
    Mar 2016
    Faisalabad
    22
    812
    17 Post(s)
    I have heard about those wires. But haven't used them. They would be better... (Quality at cost)
    But i am using the simple 8mm ones available with every shop for around 800-/RS.
    They are serving their purpose good.
  10. #2889
    margallar's Avatar
    Oct 2009
    9,957
    6
    283 Post(s)
    4 Thread(s)
    wasf, get new ultima wires and new era ignition coil. Phir proceed with troubleshooting. Else you are shooting in the dark
    haters gonna hate, potatoes gonna potate
  11. #2890
    wasf's Avatar
    Dec 2007
    38
    545
    36 Post(s)
    Quote Originally Posted by margallar View Post
    Will get them from Pindi/Islamabad as ERA coil isn't available in gujrat.i am thinking to change whatever needed after I come to you for wiring work as you will check all these electrical components & we will decide what to get.
  12. #2891
    margallar's Avatar
    Oct 2009
    9,957
    6
    283 Post(s)
    4 Thread(s)
    just get a new coil asap. This one might leave you stranded somewhere. I have exams on 23-24 and after that I am going to Lahore....
  13. #2892
    wasf's Avatar
    Dec 2007
    38
    545
    36 Post(s)
    Today I checked resistance of spark plug wires & coil wire.i checked them with multimeter set at 40 K ohms.
    1. Coil cable Bosch super sport inductive core 385 = 17 inches = 02.16 K ohms
    2. Spark plug cable 1 = Genuine Cuore T-13238 cable = 24 inches = 11 K ohms
    3. Spark plug cable 2 = ultima resistance electrical wire 18 inches= 9 to 13 K ohms ( its end near spark plug in engine has burnt rubber)
    4. Spark plug cable 3 = Genuine Cuore T-13238 cable 19 inches = 09.20 K ohms
    It looks like readings are good considering resistance value 5-8 K ohms / feet.
    Looks like coil cable of Bosch (qabli) is not resistive type cable,it is inductive maybe better then carbon & resistive cords.its reading is 02.16 which is different maybe for its type
    Please comment.
  14. #2893
    margallar's Avatar
    Oct 2009
    9,957
    6
    283 Post(s)
    4 Thread(s)
    i have seen that resistance does not matter too much, it just should not be leaking spark. That really makes things go bad.
    i just remembered, KNK is better than ultima, try to get that
  15. #2894
    midreestaj's Avatar
    Jul 2012
    223
    22 Post(s)
    @wasf, brother ground the coil your coil is not grounded as you have told. YOu can damage your coil without grounding it if it may have some life in it.
    My cables are all Sumitomo Japan
  16. #2895
    sajidahmed's Avatar
    Sep 2007
    672
    3 Post(s)
    Quote Originally Posted by capsat View Post
    clipper pins needed silicon grease. Goto Jamil autos 0300 9232821 request for diagnostics and clipper pins / piston lubrication using silicon lube
    Thanks again
    Jameel Autos is good, they lubricated the clipper pins and now it's working fine.
    During job one more issue araise that the engin Foundation are damaged and secondly the mounting farm (Guardry - Jangla) is corroded just below the A/c water outlet.
    Should I replace the whole Jangla or just repair the damage portion by welding????
  17. #2896
    margallar's Avatar
    Oct 2009
    9,957
    6
    283 Post(s)
    4 Thread(s)
    @wasf, sorry i could not get back with you. I'll be away for a month
  18. #2897
    wasf's Avatar
    Dec 2007
    38
    545
    36 Post(s)
    OK No problem I will be in touch with you.Can we get wiring work done in Lahore?
  19. #2898
    margallar's Avatar
    Oct 2009
    9,957
    6
    283 Post(s)
    4 Thread(s)
    yes, infact that is more suitable
  20. #2899
    abidirshad's Avatar
    Feb 2009
    Faisalabad
    36
    12
    If anyone wants to buy Coure carburetor (kalbi) then pm me.
  21. #2900
    abidirshad's Avatar
    Feb 2009
    Faisalabad
    36
    12
    Sorry kabli
