Page 156 of 156 FirstFirst ... 56106146154155156
Results 3,101 to 3,117 of 3117
Like Tree943Likes
Thread: Cuore Fan Club
    bilal740's Avatar
    Dec 2005
    29
    47
    Default Cuore Fan Club
    HI to all coure owners here u can post qualities of ur car compare to other its compititers like ,mehran, alto etc,,,
    (heading edited by admin/mods - spelling mistake)
  2. #3101
    midreestaj's Avatar
    Jul 2012
    223
    22 Post(s)
    Quote Originally Posted by wasf View Post
    I googled & found this Tstat valve is of Cuore ED-20 engine which is efi. As written in workshop manual there are differences in opening & valve lift temperatures. Our ED-10 cuore Tstat open at 82 but this one opens at 88 & valve lifts at 100 opposed to 95 of our Cuore's.
    Good to know brother that you installed Tstat valve that is a welcome change and you are switching to coolant. As for the valve difference it is about 6 degree C you will be running your engine hotter by almost 6 degrees. IMO, this is still in range so you wont be cooking your head gasket. But all of this based on ED20 valve thing that you have commented. I think only by looking at shape similarity you cant bet its ed20 part instead of ed10. You need to look for any marking related to temperature rating on the valve body itself and if not just be cool about it.
  3. #3102
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1019 Post(s)
    19 Thread(s)
    5
    6
    if it is EFI its 82 C if its carb its 88 C
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
  4. #3103
    wasf's Avatar
    Dec 2007
    39
    545
    36 Post(s)
    Quote Originally Posted by capsat View Post
    As per table on user manual page ED-10 General specifications has 82 ( carb) , ED-20 is European specifications ( EFI) has 88. Both are 850 cc.
    I think I should observe Tstat & housing closely if something written on it or remove it & check in boiling water temperature
  5. #3104
    midreestaj's Avatar
    Jul 2012
    223
    22 Post(s)
    thats the best idea if not sure about its temp rating
  6. #3105
    hash4u's Avatar
    May 2005
    38
    24,380
    18
    406 Post(s)
    13 Thread(s)
    13
    Like someone already mentioned diff of 8c wont kill ur engine.not having one or a stuck tvalve is not good.nothing to worry about. When feasible or whn free u can go hunt for tvalve in junkyard from similar carby engine.relax n drive n enjoy car heater in winters for now
    Sent from my GT-I9500 using PW Forums mobile app
  7. #3106
    wasf's Avatar
    Dec 2007
    39
    545
    36 Post(s)
    Today removed Tstat to confirm & it has NTC 82 C written on it so fitted back.i am happy. But while doing this work distributor settings changed a bit.
    There were some noises from dashboard side earlier which I told to mechanic he suspected AC compressor noise, so he opened its attachment nut but later he went away & another guy fitted it back but it was fitted then at maximum tension of belt, mechanic said you need to put one number small belt then this one. After setting it at such position noises increased, I showed to another mechanic he said bearing has gon bad ,should be replaced so I removed belt for tim being ,will get bearing repaired later.
    Our Mechanics complete one task but do some other thing bad.
  8. #3107
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1019 Post(s)
    19 Thread(s)
    5
    6
    bearings are replacement parts, there is nothing repairable in a bearing.
  9. #3108
    khurrampu02's Avatar
    Mar 2016
    16
    After how many kms/months tuning is requires?how long plug and point can be used plz tell in kms and months..
  10. #3109
    midreestaj's Avatar
    Jul 2012
    223
    22 Post(s)
    Quote Originally Posted by khurrampu02 View Post
    Every 6 months for tune up and point check
    Plugs 40,000 km for replacement (normal copper tip plugs)
  11. #3110
    aliraza450's Avatar
    Jul 2014
    191
    Cuore  Fan Club - 1ff5c69b48a3199b6056b6fb1db0324cCuore  Fan Club - 6e43260bb8b30ae6b9055c5e26b1eb9fCuore  Fan Club - 584a5b9f3af8b7348c41c8145534d389
  12. #3111
    aliraza450's Avatar
    Jul 2014
    191
    Replaced the dashboard guys with kabuli one, this one was with each and everything
    Sent from my XT907 using PW Forums mobile app
  13. #3112
    aliraza450's Avatar
    Jul 2014
    191
    Cuore  Fan Club - 01928656f1f1922f1021964baf7c07c5
    This dashboard has a daihatsu orignal cassette player aswell. 😎
    But radio frequency are from 76 to 90mhz only. 😞
  14. #3113
    usmanuetian's Avatar
    May 2008
    Sharjah
    31
    3,733
    67 Post(s)
    3 Thread(s)
    You can change the audio player later...no problem..
    Sent from my SM-G920F using PW Forums mobile app
    Leave sooner, drive slower, live longer
  15. #3114
    ZuLQi's Avatar
    Oct 2011
    Hyderabad
    114
    7 Post(s)
    Quote Originally Posted by aliraza450 View Post
    I see no difference in old and new
    Sent from my ZUK Z1 using Tapatalk
  16. #3115
    wasf's Avatar
    Dec 2007
    39
    545
    36 Post(s)
    Nice change. What is cost of kabli dashboard?why you changed with kabli?do kabli include speedometer, AC levers etc?
  17. #3116
    aliraza450's Avatar
    Jul 2014
    191
    Bro old dashboard was broken from the glove box compartment. Bought kabuli for 6500rs. Including each and everything Speedo , ac controls, ac duct etc
  18. #3117
    aliraza450's Avatar
    Jul 2014
    191
    Quote Originally Posted by usmanuetian View Post
    Yes sir will change the radio next month.
