Page 32 of 156 FirstFirst ... 2230313233344282132 ... LastLast
Results 621 to 640 of 3117
Like Tree943Likes
Thread: Cuore Fan Club
    bilal740's Avatar
    Dec 2005
    29
    47
    Default Cuore Fan Club
    HI to all coure owners here u can post qualities of ur car compare to other its compititers like ,mehran, alto etc,,,
    (heading edited by admin/mods - spelling mistake)
  2. #621
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    it says standard tyre size is 145/70 r12 and rear and from tyre pressure should be 26 both
    Quote Originally Posted by usmanuetian View Post
    What does this sticker show??
    how much pressure required in front and rear tires??
    can anyone explain?
    Cuore  Fan Club -1352665
  3. #622
    usmanuetian's Avatar
    May 2008
    Sharjah
    31
    3,733
    67 Post(s)
    3 Thread(s)
    Quote Originally Posted by meh1 View Post
    dabba was white? seems like this can be fixed with a rubbing compound. almost same thing happened with me. and a paint wala used rubbing compound and it is now like nothing happened. if it is white color from dabba, it can be fixed easily.
    Yes the dabba was white, but the paint has been totally removed from major portion in scratch area, only small portion got white paint from dabba.
    Once the flyovers are completed here, I will go for repaint or paint repairing, coz there is huuuuge rush on ferozpur road these days.
    and can you refer me a good and reliable paint wala here in lahore??
    Leave sooner, drive slower, live longer
  4. #623
    May 2008
    Sharjah
    31
    3,733
    67 Post(s)
    3 Thread(s)
    26 in both ???
    I have always kept 28 FR, and 30 RR.
  5. #624
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    yes tire walas recommend 28/30. 26 will give you a softer ride with good grip. fuel efficiency with be effected a bit. on good roads like in islamabad 28/30 is good. but as cuore has stiff suspension 26 in all is best.
    26 in both ???
  6. #625
    mehmood157's Avatar
    Nov 2005
    Rawalpindi
    38
    14
    Hello brotherens ..... I have got Cuore CX ECO and surprisingly I found last night that it is fitted with LandiRenzo Timing Advance Processor ..... I was setting my ride on petrol as after setting from different mechanics I was having only 7-8 Km/l ...... I am still not sure after reading this ......
    How to Adjust a Carburetor: 23 Steps (with Pictures) - wikiHow
    Are there two screws for adjusting petrol and air in cuore (as mentioned in above link) or I have to adjust a sawtooth shaped screw .... I have only found this screw on lower backside of my carburetor ....
    Also I want to ask how can I confirm that my TAP is working fine ...... ????
    Please comment ...
  7. #626
    May 2008
    Sharjah
    31
    3,733
    67 Post(s)
    3 Thread(s)
    Quote Originally Posted by mehmood157 View Post
    Please comment ...
    Did you get your engine tuned form any authorized dealer ?
  8. #627
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    that saw shaped screw is idle adjustment screw.
    Please comment ...
  9. #628
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    for good mileage do this
    1- clean air filter 2- get carburetor adjusted and tuning from toyota 3- i use total/caltex 10W oil and believe it is better 4- check wheels are rotating freely
  10. #629
    mehmood157's Avatar
    Nov 2005
    Rawalpindi
    38
    14
    Not yet brother by any authorized dealer ...
    Is there any other adjustment to control flow of fuel (petrol) in to the carburetor ......... I tried alot but did not find any ....
  11. #630
    car4you2014's Avatar
    Dec 2013
    12
    Dear All
    Any body is willing to Sell an Automatic Cuore (Petrol Only), (non CNG) in Karachi. Preferred Model is 2004 to 2006 (or may be 2007). Please send me a private message. If the car would be good. i may buy it at good rate!
  12. #631
    May 2008
    Sharjah
    31
    3,733
    67 Post(s)
    3 Thread(s)
    @meh1 @Marwanpasha
    My car is having problem
    few days ago when I started the car, It got started in 2nd try (which is normal), but engine turned off immediately, I started again, engine got start again but as soon as I move my foot away from accelerator it turns off..... this is happening randomly,Some times engine starts normally, some times this problem occurs...and it requires lot of accel push, not a lite pressure...sometimes, after few mins, everything becomes normal...
    First i thought that its due to cold engine, but this happens even on hot engine (with temp needle in mid or quarter).
    what may be the reason?? really annoyed, cant even move the car, coz when I lift my foot for brakes, engines shuts down...
    either its a fuel pump or corroborator problem??
    FYI its 2006 model
    engine is tuned properly. air filter and oil doesn't need to be changed...
    Help plzz....
  13. #632
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    for now check loose plug wire connections or faulty wires. if ok get its distributor checked for proper working. also can be problem in carburetor adjustment.
    chances are some loose connections as problem is not persistent!
    @meh1 @Marwanpasha
    FYI its 2006 model
    Help plzz....
  14. #633
    May 2008
    Sharjah
    31
    3,733
    67 Post(s)
    3 Thread(s)
    Yes I pressed the plug wires last nite, will go to toyota tomorrow for work...
  15. #634
    Marwanpasha's Avatar
    Oct 2012
    22
    2,088
    71 Post(s)
    4 Thread(s)
    this could be the problem of fuel pump... yeah good to get it checked by the dealer..!
  16. #635
    May 2008
    Sharjah
    31
    3,733
    67 Post(s)
    3 Thread(s)
    Quote Originally Posted by Marwanpasha View Post
    Fuel pump is ok, fuel filter is OK.
    It was a problem of carburetor, road side mechanic opened air filter lower plater, sprayed WD40 in carb and car was alrite ..... then I contacted person at Toyota walton so I can go to him for carburetor service, he said that "do not get your carb opened, once its opened its does not remain like before. and since car is ok after WD40 use, so just drive and chill"..... it was saturday morning...
    but.................
    this morning.
    same problem occurred again....
    now plz suggest me what should I do?? simply go for carburetor service ? or should I go to authorized dealer for other possible solutions? @meh1
  17. #636
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    seems like problem is with carburetor. first of all use a carburetor cleaner and use it. follow the instructions on it on how to use it. and report back.
    this morning.
  18. #637
    May 2008
    Sharjah
    31
    3,733
    67 Post(s)
    3 Thread(s)
    in lahore from where I can find carburetor cleaner ? and for how much?
    thank you for your reply
  19. #638
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    you can find it from any auto parts shop. Its price should be from 300-500. Remove air filter and follow instructions. I also had such problem once but mine was solved with changing fuel filter.
  20. #639
    May 2008
    Sharjah
    31
    3,733
    67 Post(s)
    3 Thread(s)
    Used carb cleaner, the car is much better now. But I will get my fuel filter change on this weekend as well. coz still there is slight missing in drive.
    thank you @meh1
  21. #640
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Hello Cuore lover.... Need your help guys ..Interested in cuore 2006-2007 what should be estimated price Tag for No Touch Up car Neat & clean (Petrol) (Manual/Automatic) ISB/LHE no....??? If you know any body please let me know...thx
