Page 38 of 156 FirstFirst ... 2836373839404888138 ... LastLast
Results 741 to 760 of 3117
Like Tree943Likes
Thread: Cuore Fan Club
    bilal740's Avatar
    Dec 2005
    29
    47
    Default Cuore Fan Club
    HI to all coure owners here u can post qualities of ur car compare to other its compititers like ,mehran, alto etc,,,
    (heading edited by admin/mods - spelling mistake)
  2. #741
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    soapy water can be used to trace leak. trace leaking place first.
    Quote Originally Posted by usmanuetian View Post
    CNG Kit Problem..
    Last week when got filled CNG after 3 months, CNG setting was not OK, called to nearest but a very good one CNG mechanic, he was v busy, so decided to set CNG on my own for the first time.
    did CNG setting after various hit and trial, and it was ok
    but now, problem is that there is some gas leak from CNG kit, I can hear the quite low sound "phsssssssssss.........", what is the reason? and what is the solution? these days I turn off cylinder valve when parking the car...
    will go to toyota walton this weekend, meanwhile any suggestion???? @meh1
  3. #742
    usmanuetian's Avatar
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    Quote Originally Posted by meh1 View Post
    in this scenario, use eagle premixed coolant. it sells for 110 rs per 1 litre can. use 3 bottles. and fill with good coolant when you can.
    hmm... ok I will look for this coolant in my next visit to market...
    Leave sooner, drive slower, live longer
  4. #743
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    Yes, I did the soapy water test, but couldnt find the leak even after trying hard. But the sound still continues "phsssss........"
    one thing, when I open cylinder valve there is no sound, as soon as I start car and turn it off, there is a leak sound and a smell..
  5. #744
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    then better get it tested from some professional. seems like it is some loose connection around kit..
  6. #745
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    went to mechanic for the said problem, it was coil piston and high pressure piston malfunction.
    got it changed, got kit service and then CNG setting
    its perfect now...
  7. #746
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    On friday went to toyota walton for:
    Oil change
    air filter change
    wheel balancing and allignment
    engine tunning
    car is butter smooth now....
    thanks to Allah
  8. #747
    Marwanpasha's Avatar
    Oct 2012
    22
    2,088
    71 Post(s)
    4 Thread(s)
    Oil change
    air filter change
    engine tunning
    thanks to Allah
    And How much load you got on your pocket..?
    Sent from my iPhone using PW Forums mobile app
    Yahoo i got the app at last...!
  9. #748
    CarSaaz's Avatar
    Apr 2008
    40
    1,648
    16 Post(s)
    cuore parts are very expensive. maybe its because i get mine maintained at dealership. even the small items like ball bearing wheels are around 2800 as compared to the chinese ones for 500 which work equally well.. the rear lights for 4500 when 2nd copy is for 1500 . i have safely parked mine in my garage and take it out once a month which is why its only done 40000 in the last 10 years MASHALLAH.
    "A government that robs Peter to pay Paul can always depend on the support of Paul. "If at first you don't succeed, failure may be your style."
  10. #749
    omarabdullah022's Avatar
    Oct 2012
    2,641
    96 Post(s)
    Quote Originally Posted by Marwanpasha View Post
    Kahan ghayyab hein sir?
    Havent seen you on the detailing thread for a while now!
  11. #750
    Oct 2012
    22
    2,088
    71 Post(s)
    4 Thread(s)
    Quote Originally Posted by omarabdullah022 View Post
    University walo ney bus pw se dori ilhtiyar kara di thi... Now i am back to my routine.. ;-)
    Pleasure to be remembered sir..!
  12. #751
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    well, total bill was 3900 rupee
    oil and filter was abt 1400
    w/b and w/all 1200 (600 each)
    air filter 1100 (purchased last month)
    and tunning 600 rupee
    then there was 10% discount on labour for appointment.
  13. #752
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    Quote Originally Posted by CarSaaz View Post
    agreed, parts are v expensive
    but the only car with cheaper oem parts is mehran, even cultus has v expensive parts.
    and NO, the chinese parts never work EQUALLY well, they have much shorter life and more liable to malfunction/broken during work than original part. Atleast this has been the case with me. So I always try to go to dealership for maintenance and parts. Spending more on original parts is trusted and worthy job.
  14. #753
    Oct 2012
    2,641
    96 Post(s)
    One more thing- chinese parts and more likely to break and leave you stranded on the road.
  15. #754
    CarSaaz's Avatar
    Apr 2008
    40
    1,648
    16 Post(s)
    like i said i dont use my cuore that much. AlhumdulillALLAH in the last 10 years since i got it, its just been serviced and waxed. The only parts ever having to be changed are the annoying wheel bearings for which i paid 2800 for the front right and 1800 each for the rear left and right . plus a 4th change was done complimentary on the rear right wheel since the last replacement didnt even last 3 months and i hollered at them. All oem japanese parts purchased , inpected and replaced by toypta eastern. My car has a full service history file from them it never goes to any guddu mechanic. When asked why the frequent change in the bearings , all they replied was "since your car is parked most of the time the bearings get weak" had a similiar complain from two of my cousins corollas.. rare usage causing frequent wheel bearing changes.
    I was comparing the Chinese wheel bearing which i placed in my charade in 2005 and still working fine MASHALLAH which i got for 300 rs as compared to the expensive oem cuore wheel bearings costing 2800.
    The build quality in local cars is very poor if you notice there is a vibration in the cuores dashboard. you have to tighten the nuts on the front. Along with that minor squeaks when pot holes approach even at dead speeds. You have to kill the speed when fat cat eyes approach you as they are sure to shake up the car and ruin the suspension.
    I like the design of cuore, the space , the fuel economy , responsive engine , road grip , driving position however like a civic it needs a clean flat road with no pot holes. The one thing i like about my mehran is i have a piece of mind knowing the parts are cheap and the feul economy is amazing.The new euros are even better. frankly its got a more soft yet equally bumpier suspension than cuore. Other then that its no match with cuore. I think its better to own a liana or city idsi in the same price range of a cuore duo to their advanced technology though parts are a bit more expensive
  16. #755
    Oct 2012
    2,641
    96 Post(s)
    Cuore is a very simple car. In my opinion it is an ideal city car. The tiny 800cc engine is very responsive and the smile jt puts on my face when i floor it in 3rd gear is just priceless.
  17. #756
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    Whatever kind of car it is, I just Love my cuore..
    .....My first car, purchased from my long savings, love to keep my car clean and in good running condition. and my homemates always say "apny pay kuch kharch nae krta, gaari pay paisay lgai jata hai..."
    One minute silence for Cuore designer...
  18. #757
    illusive255's Avatar
    Aug 2009
    619
    9 Post(s)
    Fellows i m looking to buy a cuore cx eco automatic for my father as he is not comfortable with manual transmission car due to pain in his shoulder. Can somebody guide me about fuel economy of cuore automatic and pros & cons of this car
    regards
    Diary Of A Heartbreak Kid
  19. #758
    Oct 2012
    2,641
    96 Post(s)
    Quote Originally Posted by illusive255 View Post
    regards
    Good choice. Make sure you pick a clean piece and make sure that the thermostat valve was installed in the engine and the atf was changed regularly.
    Good luck!
  20. #759
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    fuel economy of auto cuore is less than manual.
    pros: all pros of cuore + easy to drive.
    cons: low power on CNG, very low power on CNG with AC, not every mechanic can understand it. fuel economy is bad. price is more
    regards
  21. #760
    CarSaaz's Avatar
    Apr 2008
    40
    1,648
    16 Post(s)
    regards
    Cons
    1. costly parts especially if you're going for oem and from dealership
    2. hard bumpy suspension . Its fine if the roads are smooth.
    3. Interior gets squeaky after some time
    4. hard seats
    5. outdated design of the 90s
    6. lacks the refinement found in its jdm model the mira . Having same amenities yet poor material used in local car.
    7. the top of the line auto should have featured rpm meter with central locks power windows better sound system ,rims and optional airbags especially after the last price quotation of 9 lack plus.
    Pros
    1. excellent resale
    2. tough long life suspension
    3. well designed interior with good driving view
    4. wonderful semi powered steering
    5. good road grip
    6. responsive engine
    7. good brakes
    8. strong engine provided u maintain from a trusted 3s dealership
    9. good maneuvering and parking in tight space
    10. perfect for a small family
    11. its a mini Toyota
    12. fuel average is good around 13-14 in city for automatic petrol with ac though would've been better around 16-17 had it been efi.
    13. can look very nice with rims and slight modification.
    14. best local assembled car in its class
    15. rear passenger leg room and space is best in its local assembled class
