Page 49 of 156 FirstFirst ... 3947484950515999149 ... LastLast
Results 961 to 980 of 3117
Like Tree943Likes
Thread: Cuore Fan Club
    bilal740's Avatar
    Dec 2005
    29
    47
    Default Cuore Fan Club
    HI to all coure owners here u can post qualities of ur car compare to other its compititers like ,mehran, alto etc,,,
    (heading edited by admin/mods - spelling mistake)
  2. #961
    chamernazir's Avatar
    Nov 2013
    33
    308
    19 Post(s)
    thank you so very much for such a detailed description.
    just need to ask one more thing k how to replace the headlight bulbs ?
    from where should i open it ?
    Quote Originally Posted by meh1 View Post
    if headlight lens is dirty, bulbs are not getting enough voltage or bulbs are blackened then you need to fix these first. if beam is not aligned good, then this will help you.
    park at smooth surface in dark. turn headlight on. you will see 2 screws at back. tightening screw pulls headlight housing/reflector up. pulling both equally will pull beam right up. so you can use them to make it right/left and up/down. tune beam to your choice.
    Cuore  Fan Club -1425775Cuore  Fan Club -1425776
  3. #962
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    in my city it ranges from 25-30K for 660 to 850 engine. but i have heard that 1 litre KF series daihatsu engine is also available now and is a bolt on replacement. as you are from islamabad you can check and update us too. and observe all precautions before you go for buying engine.
    Quote Originally Posted by faisalbalouch View Post
    What will be cost of replacement of cuore engine?
  4. #963
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    Quote Originally Posted by chamernazir View Post
    pull the square part outside that has three wires. then remove the rubber protector. u will see a wire. push it down and up to unlock it. now bulb will be free.
    Cuore  Fan Club -1425788Cuore  Fan Club -1425789
  5. #964
    Nov 2013
    33
    308
    19 Post(s)
  6. #965
    ifoo_786's Avatar
    Aug 2011
    Fateh pur
    27
    5,955
    53 Post(s)
    30 Thread(s)
    get new gasket. why overhaul? details please
    Engine reduces Oil so i decided to overhaul it
    Quote Originally Posted by omarabdullah022 View Post
    Sorry for your loss!
    Make sure the mechanic installs the tstat valve and the the fan remains auto.
    Yeah I am doing that tomorrow
    Quote Originally Posted by usmanuetian View Post
    Ohhh...
    How did it happen ??
    Don,t know
    Quote Originally Posted by jazibdon View Post
    Now is the best time for modifying the engine.while overhauling most of your engine parts are replaced.if you get a larger size piston the car will get Ab amazing thrust plus great acceleration although reducing the fuel economy.
    Sent from my HTC VLE_U using PW Forums mobile app
    My car engine is opened for first time.. Everything was on standard installing .50 pistons . New clutch plate. And some other necessary things
    If travelling was free............ You know what i mean
  7. #966
    faizan.f7's Avatar
    Jan 2014
    95
    Cuore  Fan Club -1425922
  8. #967
    faizan.f7's Avatar
    Jan 2014
    95
    Cuore  Fan Club -1425923
  9. #968
    faizan.f7's Avatar
    Jan 2014
    95
    Cuore  Fan Club -1425924
  10. #969
    faizan.f7's Avatar
    Jan 2014
    95
    Cuore  Fan Club -1425925
  11. #970
    faizan.f7's Avatar
    Jan 2014
    95
    Cuore  Fan Club -1425926
  12. #971
    faizan.f7's Avatar
    Jan 2014
    95
    Cuore  Fan Club -1425927
  13. #972
    faizan.f7's Avatar
    Jan 2014
    95
    Cuore  Fan Club -1425928
  14. #973
    faizan.f7's Avatar
    Jan 2014
    95
    Regarding above pictures:
    I have just bought Cuore Automatic 2004 for 480K in Karachi.
    Now, I would like to carry out some tasks on it.
    From where in Karachi I could get these things done ? What would be the price for each task ?
    1. Crystal Headlights.
    2. Affordable Sound System. (Sound should be awesome)
    3. Cheap and Good Looking Rims.
    4. Seat Covers.
    5. HIDs.
    -- Do give your reviews on car's condition and price.
    Thanks in advance
  15. #974
    usmanuetian's Avatar
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    mis placed emblems....
    why?
    Cuore  Fan Club -1426079
    Leave sooner, drive slower, live longer
  16. #975
    faizan.f7's Avatar
    Jan 2014
    95
    why?
    Yes I noticed it, I'll get it fixed. Maybe because it is showered. But I was not worried regarding any big issue because I bought it from my cousin's showroom.
    Sent from my HTC One S using PW Forums mobile app
  17. #976
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    price is high for a 2004 model showered ride in karachi. but interior is neat and clean. paint quality is not good. welcome to cuore family
    Quote Originally Posted by faizan.f7 View Post
    4. Seat Covers.
    5. HIDs.
    Thanks in advance
  18. #977
    faizan.f7's Avatar
    Jan 2014
    95
    How much high ?
    And how much would it cost me to carry out all of these tasks ?
  19. #978
    faizan.f7's Avatar
    Jan 2014
    95
    How much high ?
  20. #979
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    something like 430-450 was a justified price. but my own opinion is that if working is good, all is fine. i myself get any scratch fixed fast. its my car, it should look good to me. resale? will see when i sell it . own satisfaction is more important than resale. so if it needs compounding and polish, get it done and enjoy.
    as for prices, crystal headlights came in later mode. will cost you around 5000-8000. but better clean and use original ones.
    get a alpine 2nd hand pre and 6x9 speakers for rear.4-5k for pre and 3-4k for speakers
    cheap rims will cost 8-10K and good quality rims, 15-20k. a must for sporty look.
    do you mean poshish? it can cost almost 2.5-3k
    as for HIDs it depends on quality of hids. cost 3-5k.
    How much high ?
  21. #980
    faizan.f7's Avatar
    Jan 2014
    95
    Yes, I know it costed around 20K more but It is Automatic and very very clean ride, no major work at all.
    So you are saying that all of the work would cost around 25K ?
    And what's poshish ??
