Page 60 of 156 FirstFirst ... 1050585960616270110 ... LastLast
Results 1,181 to 1,200 of 3117
Like Tree943Likes
Thread: Cuore Fan Club
    bilal740's Avatar
    Dec 2005
    29
    47
    Default Cuore Fan Club
    HI to all coure owners here u can post qualities of ur car compare to other its compititers like ,mehran, alto etc,,,
    (heading edited by admin/mods - spelling mistake)
  2. #1181
    mani001002's Avatar
    Oct 2014
    Rawalpindi
    38
    190
    7 Post(s)
    I have cuore 2001 manual
    When release cultch on idle or low rpm i feel viberation but with minor accelerator its fine
    Left wala joint(goda)b awaz karta hai turning pa
    Kindly suggest me
  3. #1182
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    Quote Originally Posted by mani001002 View Post
    Hy how can i join cuore fan club
    to join this club you just have to like cuore. welcome!!
  4. #1183
    mani001002's Avatar
    Oct 2014
    Rawalpindi
    38
    190
    7 Post(s)
    Cuore is the first car in my life 2001 T/ metallic total genuine minor wear and tear
    A/C petrol and cng but now driving on petrol here in RWP.
    Worth 350000/-
    Facing two problems
    1.viberating dash board jab accelerator kay bagir first gear ma clutch choro or agar accelerator thora daba k clutch chooro tu thik chalti hai no vibration
    2.petrol average kasy behtar ho sakti hai plug.point.condensor.oil filter.fuel filter.balancing. alignment. Gear oil.disc pad.rear leathers.coolent sab new dalwai han
    Oil caltex hevolien formula dalwaya hai.
    Abhi long pa 13.5 ki average da rahi hai
    Any suggestion plz for better performance
  5. #1184
    faizan.f7's Avatar
    Jan 2014
    95
    Quote Originally Posted by shafi8189 View Post
    I had the same problem the mechanic adjusted tappets and problem solved runs fine both petrol and CNG
    Bro, are you sure ? Tappets tight karne se masla solve ho jaaye gaa ? or there could be anything else If you are aware of it ?
  6. #1185
    shafi8189's Avatar
    Sep 2013
    27
    333
    13 Post(s)
    Quote Originally Posted by faizan.f7 View Post
    Their is some adjustment that need to be done my car problem was that I could not drive on cng and on petrol it worked fine could be timing,tappets,cng mixture get them all looked out by a professional cng mechanic
  7. #1186
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    Worth 350000/-
    Facing two problems
    a total original 2001 from rawalpindi should me more than that.
    for vibration, the causes can be, 1-Engine needs tuning, 2-broken engine mount 3- loose screw in dashboard or something broken. specially check bolts in middle of dashboard under the deck.
    this average is low. car dhuwan deti hai? masla carburetor main lagta hai.
    for better performance use 5w-30 oil. i have used shell helix hx7 5w-30 and it engine gives much better performance and economy. but for longer engine life 20w-50/15w-40 oil is better .
  8. #1187
    fezan.x's Avatar
    Nov 2013
    27
    104
    2 Post(s)
    Kindly suggest me
    About vibration : Seems like clutch issue, may be @meh1 can give a better expert opinion
    The joint thing: Seems axle issue
  9. #1188
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    @fezan.x and @mani001002 if vibration is in clutch pedal, its clutch issue. otherwise there can be other causes. when axle starts to sound, u need to replace it. repair also can work. don't use regular grease. use CV joint grease and take care of rubber boot and replace it as soon it is torn off. unlike other small cars, cuore's axles work easily for 4 5 years.
  10. #1189
    usmanuetian's Avatar
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    Get ur engine tuned
    Dont go for tappet tightening
    Ask mechanic to adjust as per standard using filler guage.
    Leave sooner, drive slower, live longer
  11. #1190
    mani001002's Avatar
    Oct 2014
    Rawalpindi
    38
    190
    7 Post(s)
    Clutch pedal is smooth and silky no vibration in padle
    Ma last sunday mechanic k pas gaya tha us na hand break lagwa k first gear ma clutch chorna ko kaha without accelerator khud woh boo net khol k front pa khara or observe kar raha tha
    Abhi woh kahta hai k both engine mounting need to b replaced.....
    Using havoline formula 10...30
  12. #1191
    mani001002's Avatar
    Oct 2014
    Rawalpindi
    38
    190
    7 Post(s)
    Cold start pa engine ziyada viberate karta hai jab ghari garam ho jati hai tu viberation bhat kam ho jati hai
  13. #1192
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    I was away from the club due to busy work schedule. Was appearing only in nmc.
    Today took my car to toyota walton motors for rear fender repaint.
    Before handing over the car, the person there took about 20 to 30 pics of my car, also took my picture
    Odo, doors, bonnet inside outside, doors inside, seats, dash, steering, dickey .... pic from every angle..which was quite surprising for me.
    Now will go tomorrow to take delivery. Following are the pics
    Dealership person taking pics...
  14. #1193
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    Go for cng setting
    If not solved, get ur engine tuned
  15. #1194
    mani001002's Avatar
    Oct 2014
    Rawalpindi
    38
    190
    7 Post(s)
    Masha allah usman
  16. #1195
    mani001002's Avatar
    Oct 2014
    Rawalpindi
    38
    190
    7 Post(s)
    Bro no cng driving on petrol
    Lakin cng utrwana k bad engine or carburetor tune nhi karwai
  17. #1196
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    Masha allah usman
    Kis baat ka ma sha Allah bhai jaan??
    Tomorrow when I will share pics of painted panel, then say ma sha Allah...:p
  18. #1197
    fezan.x's Avatar
    Nov 2013
    27
    104
    2 Post(s)
    Quote Originally Posted by usmanuetian View Post
    Like the prosmatec tag ,
    By the way bro very nice car you got, neat and clean mashahALLAH
  19. #1198
    fezan.x's Avatar
    Nov 2013
    27
    104
    2 Post(s)
    Bro please share the cost of repaint.
  20. #1199
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    Quote Originally Posted by fezan.x View Post
    Its 4200 rupees. It includes about 600 rupee as a labour tax.
    Dealerships are always xpnsive, but I went there for two reasons,
    Paint quality, paint matching and second, I will never leave my car to local mechanic due to their 2 nmbriaan..removal of original parts and petrol etc etc
  21. #1200
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    Car is at workshop, so the rear tray team will stay in cupboard for few days.
