Page 65 of 156 FirstFirst ... 1555636465666775115 ... LastLast
Results 1,281 to 1,300 of 3117
Like Tree943Likes
Thread: Cuore Fan Club
    bilal740's Avatar
    Dec 2005
    29
    47
    Default Cuore Fan Club
    HI to all coure owners here u can post qualities of ur car compare to other its compititers like ,mehran, alto etc,,,
    (heading edited by admin/mods - spelling mistake)
  2. #1281
    usmanuetian's Avatar
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    Quote Originally Posted by meh1 View Post
    hot water from engine comes in heater core. when we set knob to hot, all air goes through it. when at cold, air goes direct to vents. water temperature is always at 82. its controlled by thermostat valve, and fan.
    "Air goes direct to vents" means simple cabin air is recirculated??
    Leave sooner, drive slower, live longer
  3. #1282
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    Quote Originally Posted by usmanuetian View Post
    yup, at first entry of air(from cabin/outside) is controlled through ventilation lever. this in behind glove box. then it passes through a/c evaporator. now comes 2 passages, through heater or not. at last there r different circulation paths(front,down vents and defogger vents.
  4. #1283
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    Default Please answer ...
    This problem is quite old in my car, and Im discussing it here for first time.
    The problem is that my car has a continuous sound of "guuuuuunnnnnn....." when engine is running, whether its on idle or moving on road, this sound is always there. my engine is finely tuned, petrol setting is perfect, oil and air filter changed few weeks back, but this noise is still there, what could be the reason and what would be the solution?? its more than what we have in other cars, its quite louder....
    cabin has this weird sound ........ "guuuuuuunnnnnn....."
    plz help....
  5. #1284
    mani001002's Avatar
    Oct 2014
    Rawalpindi
    38
    190
    7 Post(s)
    Bhai kahen engine ki vibration convert ho k cabin ma transfer tu nhi ho rahi
    Yah cabin ma koi asy chez hai jo noise paada kar rahi ha
  6. #1285
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    Quote Originally Posted by mani001002 View Post
    its engine vibration... not any rattling item in cabin...
  7. #1286
    burnoutrevenge's Avatar
    Mar 2012
    193
    10 Post(s)
    I have a similar problem. Like at a low rpm, the engine's sounds split and start to sound like a diesel engine :p Wohi ghrum ghrum wali awaz jo 2 0d main ati hai.
    So, I showed it to a mechanic and he told me that one of the foundations is broken. That causes the engine to vibrate resulting in reverberations at specific rpms.
    U might have a similar problem. Get ur foundations checked.
  8. #1287
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    Quote Originally Posted by burnoutrevenge View Post
    Exactly, that 2D engine sound.i have that sound on higher rpms aswell...so did u get ur foundation repaired?
    Foundation means engine mounting na???
  9. #1288
    Mar 2012
    193
    10 Post(s)
    Yeah I will get them changed soon. M planning to go to Toyota for their opinion. And while I am at it, will get the suspension checked as well. The manual says it needs to be checked at 50000 km. Will let you know what the mechanics at the dealership say.
    One of the mechanic said that the foundation doesn't necessarily need to be broken for the diesel sound to come. If one of the foundations (rubbers) are hard, they will produce the sound as well sincev they won't be able to damp the vibrations
  10. #1289
    mani001002's Avatar
    Oct 2014
    Rawalpindi
    38
    190
    7 Post(s)
    Mostly assa hota hai k mounting crack hoti ha lakin physically thik mazar ati hai or wasy b kafi difficult hai engine mounting ko bonnet ma judge karna
    Ap assa karan k kisi or ko driving seat pa bethain or khud bonnet khol k judge karan...hand break lagain or car ko first gear ma la k slightly sa clutch paddle release karan ghari band nhi honi chahya idle pa he yah test karan just clutch use karna ha
    Ap easily judge kar sakty hain ka kon si mounting break ha ya soft ho chuki ha
  11. #1290
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    As per my telephonic discussion with person at toyota walton, he said "there are three mountings, one for gear box and two for engine, and its 80~90% chance that gear box mounting has been cracked or hardened. and gear box mounting original costs 5700 rupee with labor 1500 for change, and engine mounting is about 2400~2500 rupee"
    So I will go to toyota walton for check up this Saturday, then will decide.
    Thanks for your help guys...
  12. #1291
    mani001002's Avatar
    Oct 2014
    Rawalpindi
    38
    190
    7 Post(s)
    Bhai orignal gear mounting 1000 ki bilal ganj sa mil jati ha mara pass pari ha lakin abhi lagwaya nhi ap easily dakh k judge kar lan *** k mounting kis halat ma us k rubber ko thora hard hona chahya flexibility bhat kam ho
    Ma b khud he dakh ka laya hon
  13. #1292
    mani001002's Avatar
    Oct 2014
    Rawalpindi
    38
    190
    7 Post(s)
    Customizing cuore meter
  14. #1293
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    Nice
    U already have non stock meter
    Do share final pics
  15. #1294
    mani001002's Avatar
    Oct 2014
    Rawalpindi
    38
    190
    7 Post(s)
    Finally done
    Cost 1600( labour + installation)
    From saddar Rawalpindil
  16. #1295
    chamernazir's Avatar
    Nov 2013
    33
    308
    19 Post(s)
    headlight of my Coure got broke.
    i need to know that is it possible that i only replace its front glass rather than installing a whole new light (because only the glass has broken) ?
    if the glass can be replaced then how much is it gonna cost ?
  17. #1296
    Nov 2013
    33
    308
    19 Post(s)
  18. #1297
    Nov 2013
    33
    308
    19 Post(s)
  19. #1298
    faheem14's Avatar
    Mar 2011
    177
    Thats looks Good.
    How much RPM Metre cost ?
    Can you give contact number or Exact location of Saddar , i want to do same work as your car Metre when i come Rawalpindi from lahore. I unable to find Mechanic in lahore for this kind of work.
  20. #1299
    faheem14's Avatar
    Mar 2011
    177
    Thats looks Good.
  21. #1300
    Nov 2013
    33
    308
    19 Post(s)
    Quote Originally Posted by faheem14 View Post
    Thats looks Good.
    have you tried changing the stock bulb to LED's ?
    i have heard that such LED's are available in market which can be easily fitted in place of stock bulbs.
