Page 82 of 156 FirstFirst ... 3272808182838492132 ... LastLast
Results 1,621 to 1,640 of 3117
Like Tree943Likes
Thread: Cuore Fan Club
    bilal740's Avatar
    Dec 2005
    29
    47
    Default Cuore Fan Club
    HI to all coure owners here u can post qualities of ur car compare to other its compititers like ,mehran, alto etc,,,
    (heading edited by admin/mods - spelling mistake)
  2. #1621
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    Quote Originally Posted by ifoo_786 View Post
    Aoa. . . . What should be tempreture of engine while AC running now a days. I removed t state valve. Fan direct but reaches middle of guage and stays there either car moving or not. Radiator serviced yesterday but no difference at temp.
    direct fan and no t.valve and needle at middle means big problems in cooling or engine is over heating. in this condition ur needle should move without AC and move a bit with AC. is ur temp gauge fine?
  3. #1622
    usmanuetian's Avatar
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    Quote Originally Posted by meh1 View Post
    one side only? i think it is very old boot. get a boot from outside market and get it replaced by toyota. make sure your rims and axles are not heating up due to anything.
    On 23rd Jan , meter reading 91993 , left right both outer were changed
    On 12th Mar, meter reading 93163, left outer changed, and seal of inner changed with grease refill
    Now its 17 apr, reading little above 94k, left outer damaged
    I dont think that rim or axle are getting heat from anywhere....
    what do you suggest now??
    Leave sooner, drive slower, live longer
  4. #1623
    mani001002's Avatar
    Oct 2014
    Rawalpindi
    38
    190
    7 Post(s)
    bhai upar wala solenoid ka connection hai. neeche wala switch ka connection hai jo turbo ke sath use ho sakta hai. upar wale ki wire connected hai na?
    Wire sath hai lakun connected nhi
    Ap batian k woh wire lagay ge kahan or solenoid ka function kiya ha
  5. #1624
    khan_ji's Avatar
    Jul 2014
    130
    2 Post(s)
    it is normal condition dont worry...
  6. #1625
    muhammad.ali1231's Avatar
    Feb 2015
    48
    Quote Originally Posted by usmanuetian View Post
    bro this position is normal, if it crossed mid point then its dangerous..
    but after 5 mins of start up it shouldn't reach there. its too early.
    R u using coolant or simple water in radiator?
    i bought car 7months ago.dont know is it coolant there or water.but radiator dont reduce water. i warm up my car before going anywhere at morning time.if it goes little long like 10 to 20mints then gage goes at middle and auto fan starts and after some time it goes off.
  7. #1626
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    Quote Originally Posted by muhammad.ali1231 View Post
    Congrats for ur purchase.
    Its good to warmup engine before moving. After 10 to 20 mins then its ok and no problem.
    But just one friendly suggestion, use a good quality coolant in radiator. Also its summer and AC will also b in use now.
    Btw Which model it is and mileage??
  8. #1627
    Feb 2015
    48
    it is 2007 mileage near to 85,000kms
    thinking to put coolant of caltex.is that coolant ok ?
    and one more thing.should i service the radiator or just clean it with presure water from service station ?
  9. #1628
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    Yes I have heard good repo of caltex. If u can find original one, must go for it.
    If radiator is not too much rusty, then no need of service, just drain the system completely, fill the plain water, and do it 2 to 3 times, then drain complete and top up with a good coolant.
    Im using zic, started using frm last year.
  10. #1629
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    what should be the frequency of fuel filter change???
  11. #1630
    kylr.shah's Avatar
    Dec 2014
    22
    32
    which radiator should be use in coure ? and cost of it?
  12. #1631
    ifoo_786's Avatar
    Aug 2011
    Fateh pur
    27
    5,955
    53 Post(s)
    30 Thread(s)
    Quote Originally Posted by mani001002 View Post
    Using coolant or water
    Radiator kon sa hai plastic body wala ya copper wala
    Using plain water and i m posting pic of radiator
    What should i do and what to check ?
    If travelling was free............ You know what i mean
  13. #1632
    ifoo_786's Avatar
    Aug 2011
    Fateh pur
    27
    5,955
    53 Post(s)
    30 Thread(s)
    Guage seems to be ok bcoz when i pour some water on the top of radiator guage climb down to C mark . What should i do ?
  14. #1633
    mani001002's Avatar
    Oct 2014
    Rawalpindi
    38
    190
    7 Post(s)
    Quote Originally Posted by kylr.shah View Post
    4000 denso plastic body with one year warranty with reciept,old radiator price 1000
    From saddar Rawalpindi
  15. #1634
    ifoo_786's Avatar
    Aug 2011
    Fateh pur
    27
    5,955
    53 Post(s)
    30 Thread(s)
    Went to mechinic he said its ok until radiator reducer water. Ratiator doesn,t reduce water so should i worry or not ?
  16. #1635
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    are you sure thermostat valve is removed? what if radiator is not reducing water and is clogged?
    anyway in this condition u can drive but take care of temperature while u drive. there is no harm if it stays on half. normally it stays at 1/3 although.
  17. #1636
    Feb 2015
    48
    any cheap solution of this ???
    Cuore  Fan Club -1566449
  18. #1637
    Feb 2015
    48
    Cuore  Fan Club -1566450
  19. #1638
    Feb 2015
    48
    Cuore  Fan Club -1566451
  20. #1639
    mani001002's Avatar
    Oct 2014
    Rawalpindi
    38
    190
    7 Post(s)
    No reply ?
  21. #1640
    May 2008
    Sharjah
    31
    3,729
    67 Post(s)
    3 Thread(s)
    Bump.....
